Cleaning rusted gas tank with Citric Acid
Showing 1 to 7 of 7 results
ferraridoctor
Send a private message to ferraridoctor
Has anyone used Citric Acid to clean a rusted gas tank (not diesel).
Thu, Jan 19, 2012 10:49 PM
cojhl2
I used Muratic acid. Works very well. After a shot time of soak neutralized with healthy rinse and baking soda.
Fri, Jan 20, 2012 11:51 PM
Oil Slick
Reply to cojhl2:
If you put some easy to fish items like large bolts and nuts in the tank and tumble it. This will help break off the flakes of rust.
Sat, Jan 21, 2012 12:01 AM
zootownjeepguy
Reply to Oil Slick:
I use a length of chain in the tank to knock the crud loose. Works great and MUCH easier to remove than nut's & bolts. Just hook the chain with a piece of wire and pull it all out at once.
Rich Salvaggio
D2 5U9917
Sat, Jan 21, 2012 5:29 AM
mdkrusemark
Send a private message to mdkrusemark
Reply to zootownjeepguy:
The gas tanks I get all go to my local radiator shop and get acid cleaned (don't know what acid they use) and put in a hot tank. Then after that they get sealer put in them and they are all ready to go. Just had a tank off a john deere 620 done for about 100 bucks. It seals all the pinholes. They said it will even seal up to a 1/4" hole if they tape the outside, I wouldn't recomend that though.
Sat, Jan 21, 2012 5:37 AM
carlsharp
Send a private message to carlsharp
Reply to mdkrusemark:
A great tank cleaner is some small chain welded onto about 2 feet of 3/8 rod and chucked to an electric drill. Just hang on tight!! 😊
As far as repair/coating the best (IMHO) is POR-15 (google it) because it comes with a gunk and rust dissolver as well as a thick coating that will fix even severe rusted out sections. Just put duct tape on the outside to support the sealer til in hardens.
Carl Sharp
Chino, CA
2xPV15; 22 2F; D4 5T
Various other oddball stuff
Vids: http://www.youtube.com/profile?user=carl4043
Sun, Jan 22, 2012 1:00 AM
zootownjeepguy
Reply to carlsharp:
I'll second that! POR-15 is GREAT stuff,...just don't get any on you or you'll wear it for a week. About 14 years ago I painted the underside of my small trailer with POR-15 and it's still holding up like new (the trailer stays outside in the weather year round since I painted it too).👍👍👍
Rich Salvaggio
D2 5U9917
Sun, Jan 22, 2012 1:51 AM
Bill Glenn
Thank you received: 6
My daughter Andrea had a really good idea about this that she put into practice... she put sections of tire chains in a gas tank and tumbled the loose rust off. The chains were easy to get out and did a great job.
Bill Glenn
Sun, Jan 22, 2012 3:15 AM
