Caterpillar sixty cab help
Showing 1 to 10 of 13 results
AntiqueCatman21
Send a private message to AntiqueCatman21
Happy New years everyone. Was wondering if anyone out here has any literature or blueprints for a cab. I'm starting a project this winter on a snow special sixty. Any info would be helpful . Also needing 2 rear fuel tank brackets thanks Kenny
Sat, Jan 3, 2026 1:37 PM
Thank you received: 287
Is it snowing in Petaluma, CA today? Tell us about your poaching expedition. I am envious of you as always. JM
Sat, Jan 3, 2026 3:58 PM
Thank you received: 78
I like your trailer. What brand/model is it, and what's its tare weight?
Sat, Jan 3, 2026 6:55 PM
Thank you received: 227
Slippery roads, could cause loss of traction and the whole thing could just find its way elsewhere - sorry, no room for it here (can't blame an old man with lots of memories can you? Nice catches, enjoy, safe travels! Looking forward to seeing the restoration and completion. Of all the machines I have had the opportunity to be sitting in the seat, I think the Sixty brings that thrill back every time I am around one. Thanks for sharing the pictures and keeping our machines alive. - cts
Sat, Jan 3, 2026 7:03 PM
wimmera farmer
Thank you received: 10
Sat, Jan 3, 2026 8:58 PM
Looking good Wimmera Farmer! What do you do if you have to adjust the clutch, cab looks very close to the flywheel. - cts
Sat, Jan 3, 2026 9:52 PM
wimmera farmer
Adjusting the clutch is not my problem unfortunatly.
Sat, Jan 3, 2026 10:40 PM
Thank you received: 140
Hi, cts.
I have heard rumors that Cat dealers used to keep trained Ourang Outans back in the day just for jobs like this. Sadly, times seem to have changed and I have never seen any of these critters at a Cat dealer.
Sat, Jan 3, 2026 11:38 PM
Wombat
Donor
Myron Porter in Nebraska built the cab for me, I am guessing about ten years ago, don't know if he is still alive. My biggest problem now is to find a smart sheet metal worker to roll a bonnet, I gather it will take someone who is exceptionally good at it, to be able to get the front and rear shapes correct and a piano style hinge down the middle, all in the same two sheets.
Clutch adjustment is not that difficult, just need some patience.
Regards, Wombat
Sun, Jan 4, 2026 2:14 AM
AntiqueCatman21
Thanks It's a Murray 35ton air tail weight is 16xxx I think
Sun, Jan 4, 2026 3:13 AM
Very nice!
Sun, Jan 4, 2026 2:05 PM
