Caterpillar fifteen
Caterpillar fifteen
Showing 1 to 10 of 24 results
james-thompson-3475
Send a private message to james-thompson-3475
My wife and I have been working on our new project. 1929 fifteen ser# pv721 I have a question regarding the clutch. Hope this picture comes through. After removing the two bolts on the adjustable collar and moving it towards the I’m transmission there is a large nut between the throw out bearing oiler and the clutch brake disc. On my machine that nut spins freely with no threads to screw on to. It has a keeper on the transmission side. When I bolt the collar back in place I have my 1/16 “ gap between disc and plate. I can’t believe that is supposed to be threaded to nothing. Anyone have any ideas as to what is wrong ? The clutch works. Thanks Jim
Wed, Nov 18, 2026 10:32 PM
Thank you received: 78
You can consult the parts catalog to see what is supposed to be there. It could be that that nut and that adjacent piece are custom spacers someone put in. A Fifteen expert will be able to chime in if what you show here is OEM
Wed, Nov 18, 2026 11:40 PM
Thank you received: 95
it could be that the front nut has backed off of the transmission shaft clutch end threads and the shaft has moved rearwards making it appear there are no threads on the shaft.
If you look in the rear at the PTO end to see if the rear nut and bearing on said shaft have backed out of its bore in the trans. case--if so gently tap the trans. shaft forwards and the threads may appear at the clutch end.
It may be that the spigot bearing has disengaged from the outer race and rollers so be careful not to get too vicious re installing the shaft in to there as well as it may need support to align said spigot bearing.
I only have a PV Fifteen Instruction Book and have attached a scan from it showing a part assembled shaft assembly.
Hope this helps.
Thu, Nov 19, 2026 2:28 AM
james-thompson-3475
Thanks for the thoughts and information. I will take off the rear access cover and see if I can push the PTO shaft forward. Won’t happen till this weekend. I’ll keep you posted. We have most parts cleaned and painted,ready for it’s new lease on life.
Thu, Nov 19, 2026 1:45 PM
side-seat
That’s the nut that holds the clutch brake to the top shaft.
Thu, Nov 19, 2026 2:21 PM
side-seat
Thu, Nov 19, 2026 2:31 PM
side-seat
Thu, Nov 19, 2026 2:37 PM
side-seat
I meant to say the nut holds the hub where the clutch brake attaches to.
Thu, Nov 19, 2026 2:41 PM
side-seat
Thu, Nov 19, 2026 2:50 PM
side-seat
Thu, Nov 19, 2026 2:54 PM
side-seat
Thu, Nov 19, 2026 3:02 PM
