Caterpillar D2 engine fault update
Showing 1 to 10 of 23 results
MARTYN WILLIAMS
Fitted a replacement pump and yolk. Ran diesel, a big improvement, no thick black smoke but still a bit of a pop on number one cylinder. nowhere near as bad as it was before. Coolant system, no bubbles, no leaks, engine oil spot on the mark.
Do you think it could be a combustion chamber or a valve problem, perhaps pump out one tooth on rack, but looks in uniform with others ? It pops but smoke is not blue, just grey sometimes. Like an International tractor before it warms up lol
Any ideas ?
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Wed, Jul 16, 2014 10:55 PM
Could it be a bad injector? I can't remember if you checked them already?
Are dots on pump quadrant and rack aligned? Had a more modern pump on a D320 that had some stuck plungers and pulled the pumps out to free them up. Didn't get them timed up correctly when they were replaced.............had a really "interesting" sound. Went back and did the job properly and it smoothed right out. That was on first startup after a new overhaul though. \
I wonder if the fuel pump lifter dimension is correct with the new parts.
Carbon buildup in the cylinder as a result of running with the other pump could still be causing problems?
Thu, Jul 17, 2014 1:43 AM
MARTYN WILLIAMS
Injector has been overhauled, used pump fitted. ( unknown quantity but dont think its the problem) This tractor has always ran clear . Overhauled it 18 years ago. When I first had this tractor it had a problem with a combustion chamber,pin hole in it. All were removed and defective ones replaced. Ran good till this fault developed with little warning. I remember seeing some D2's and 4's at shows popping in a similar way till they were worked hard. But this Diesel engine starts good and has always ran sweet .The original injector was "hoseing" on bench test. The plunger does not stick now after a clean up. Pump timing checked twice. Could a fracture in the combustion chamber cause this problem ?
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Thu, Jul 17, 2014 5:18 AM
Part of the reason that D2s are rather cold blooded starting and also why they're more susceptible to hard starting when worn is the small diameter of the cylinders. Pistons and bores shrink a certain percentage for each degree of temperature drop. The smaller the diameter of the bore, the higher the percentage of the cross section is exposed by the same percent shrink because of thermal expansion (or the opposite). The poor D2s are such small bores that they have a hard time making enough heat to combust on a cold startup because the blowby from the shrunken pistons is so much higher than for a larger bore engine.
Pete.[/QUOTE]
I don't know where your getting your information from but your analysis is not entirely correct. The increased dimension is based on the coefficient of expansion for the material considered and is not based on percentage and is not always linear.
It is a bit of a challenge to consider all the variables involved but actual operating temperatures of the piston are much lower than the combustion temperatures due to heat transfer to the cooling system, oil cooling and incoming air flow.
At the heat transfer coefficient of 0.0000123 inches per inch per degree F. for aluminum the difference between say a 3.75" piston and a 4.75" piston is only a few thousands of an inch. Results being heavily influenced by the temperatures plugged in to the calculation.
Fri, Jul 18, 2014 12:12 AM
Thank you received: 78
Pete, interestingly some diesels run with a really low compression ratio. My father has a Lister CS 6-1 which starts on 17.5 and then once running is as low as 14.5. Worn, they'd have to be even less than that. Some gas engines are up in that range which kind of amazes me that they can run that high.
The Listers "always" go though. Youtube it or Listeroid, which are Indian or Chinese-made clones. Great engines for low power, slow-running, long-running applications. My father's one was a lighting plant, putting out 32V direct current to a set of alkaline batteries. Ran that for a few years before mains power came to the farm. This engine is like Dad's - the late model Chinese generator isn't…
http://www.youtube.com/watch?v=KSwhDSY8LHQ
Fri, Jul 18, 2014 5:29 AM
Most of that hard starting is due to the fact that the engines are flat worn out. That means rings are worn, ring lands are out of spec, ring end gap is to large, cylinder bores are worn and have excess taper and for those "recovered" stuck engines the rings may not be functioning at all. If it wasn't for the pony exhaust heat they probably wouldn't start at all.
These old engines that we are dealing with are all about 17:1 compression ratio. They need a compression temperature of 750 deg. F or so to obtain auto ignition, 1000 deg. F or better to run efficiently. That's not to say that pistons and liners live in that temperature, probably about half of that when heat transfer/cooling is considered.
Every material has its own coefficient of expansion/contraction, cast iron about half that of aluminum. Yes, I guess foundry folks like to express shrinkage as a %. Still has to calculated from the materials properties.
Fri, Jul 18, 2014 6:30 AM
catsilver
I'm working with diesel engines here that run with around 14:1 compression ratio, this is enough to put cylinder pressure above 300 PSI at cranking speeds and they fire up straight away without any starting aids.
Fri, Jul 18, 2014 5:30 PM
Reply to catsilver:
Pete, I read your initial reply yesterday, laughing so hard I almost fell out of my chair!
OM's reply is pretty much spot on, slight variations but the facts are there!
Catsilver---your a CAT mechanic? True the Turbo engines are 14-1 compression and yes they will start easy as long as they are above 65 degrees F (at least on the Gensets). As they go to rated and need to start right now, typically they have Block Heaters on them.
Fri, Jul 18, 2014 6:32 PM
catsilver
Reply to drujinin:
Yes I was a Cat master mechanic, I did 45 years with a Cat dealer, 13 years on the spanners before going to staff engineer, warranty supervisor, PSSR, service manager etc for the remaining 32 years, I am now past retirement but still work selling someone else's marine engines, we have a 22 litre V12 which runs at 14.3:1 CR and even in our coldest UK winter weather they will always start, usually before they have turned a full 360 degrees. The only start aids we have ever fitted have been block heaters for use in the Arctic circle.
The Cat 3208 always started very well without aids, the last 435HP marine engine was 15.5:1 CR, but tended to smoke until warmed up as most low compression turbo/aftercooler engines do.
The old Cats were not wonderful starters because they were relatively low compression, indirect injection, low injector pressure and just can't compare with more modern units which have at least double the injector opening pressure for far more efficient fuel atomisation.
Fri, Jul 18, 2014 7:07 PM
Reply to catsilver:
I'd like to see the calcs on how they achieve auto ignition at 14:1 compression, 300psi and ambient temperatures.
Fri, Jul 18, 2014 10:21 PM
MARTYN WILLIAMS
Hello all
I spent most of my time working on diesels of around 3300 horsepower. The GM engines employed in our locos can be hard to start if not run for say a weekend in cold weather. They are V12's
Back to the D2, I did notice that number one cylinder runs hotter now that the others after I changed injector and pump. Did an "autopsy" of the pump I removed. The internals had not moved, there was corrosion on some of the parts. I am now thinking about a possible fault with the combustion chamber or valve seats on number 1 cylinder. What do you guys think ? The diesel starts well after the usuall start procedures.Used my rotovator today, starts on second pull every time. Has anyone tried to fit electronic ignition to a D2 /D4 pony to make them more reliable ?
This is youtube footage of a loco that I was called out to
http://youtu.be/1YbnZHnG04M
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Fri, Jul 18, 2014 10:43 PM
