Cat Twenty
Cat Twenty
Showing 1 to 10 of 23 results
dmgrow
Send a private message to dmgrow
[attachment=51095]IMG_0939.jpg[/attachment][attachment=51094]IMG_0933.jpg[/attachment]
I want to verify the serial number, has L187 on seat rear. Cannot find a number on the engine or trans top. Looking at trans pic can someone explain where I should be looking? The hood is interesting, adds at least 10hp. Is it factory or shop made?
Thanks,
David
Wed, Oct 17, 2018 11:30 AM
Steve A
There is a serial number stamped at the edge of the rectangle plate over the steering clutch adjustments, between the seat and steering clutch levers. sitting in the seat it will be on the top left side of the cover plate stamped in the cast housing.
Wed, Oct 17, 2018 5:20 PM
janmeermans
Reply to Steve A:
In my opinion, the hood looks to be custom-made and not factory. I have never seen one like it.
Steve is correct on the stamping location.
JanM
Wed, Oct 17, 2018 8:27 PM
Thank you received: 62
Reply to janmeermans:
JanM
I know nothing about serial numbers on gas Cats, but that hood just has to have a story to tell.
But the chances to find that story cannot be good.
I know if you find the story it will be very bland.
Wed, Oct 17, 2018 9:44 PM
Tad Wicks
Reply to Ray54:
Has the seat back been bobbed off, seems mine is much higher than that.
Wed, Oct 17, 2018 11:19 PM
dmgrow
Reply to Tad Wicks:
Someone extended the seat box by 4". That will be the next item to address.
Thu, Oct 18, 2018 4:12 AM
dmgrow
Reply to dmgrow:
I forgot to add, thanks for the info. I will go look again over the weekend for the s/n. It seems to be a nice running machine. I plan to pull the pan and check the bearing clearances over the winter and I will soon be on the "for sale" forum looking for parts. I will post further pics of what I find.
Thu, Oct 18, 2018 4:26 AM
wimmera farmer
Thank you received: 10
Reply to dmgrow:
Reading this thread prompted me to look at my twenty. Ser No is between the two grease nipples for steering clutches on mine, a little to the right of center.
Also realised I am missing the brass tag on the steering clutch adjuster cover. Anyone know of reproductions available.
cheers WF
Thu, Oct 18, 2018 4:42 PM
ianoz
Reply to wimmera farmer:
cheers WF
I will check with Byron, Pretty sure he has made all the early machines Brass plates .
Thu, Oct 18, 2018 6:05 PM
ianoz
Reply to ianoz:
Had a quick look on his forum .Plates are by part number,If you have the plate part number , it will help me track it down quicker for you .
Thu, Oct 18, 2018 6:15 PM
GrantJ
Online
Thank you received: 13
dmgrow, where are you located. I have a big 20 parts machine I will be parting or selling the whole thing including an angle blade setup. Grant.
Thu, Oct 18, 2018 10:03 PM
