cat thirty fan shaft
gibsonf5
Send a private message to gibsonf5
i have a question about oil dripping from the fan shaft of my thrty while its running. i figured their must be packing or a an oil seal around the shaft but after looking at the parts manual i dont see either one. thought i had better ask before taking it apart. is oil dripping while its running common on these or is there a fix? what seals the oil or is there any seal? its not a bad drip but it makes it way to the fan blades and after that its everywhere. thanks a million, eric
Mon, Jul 15, 2013 10:06 PM
chriscokid
if i am not mistaken, there is a drip hole in the housing that holds the bearing, if this hole gets clogged then the oil will not be able to run back into the housing but leak out the front.
Mon, Jul 15, 2013 11:57 PM
gibsonf5
Reply to chriscokid:
thank you kind sir, this i will look into. God bless, eric
Tue, Jul 16, 2013 1:35 AM
rturn3060
Send a private message to rturn3060
Reply to gibsonf5:
For some reason I haven't been able to log on to this site until today after many tries so my response is not timely. I have had good luck replacing the outer bearing on thirties and sixties with a sealed bearing thus eliminating the oil that usually seeps out around the fan shaft. RT
Fri, Aug 2, 2013 11:30 AM
D2BIGED
Send a private message to D2BIGED
Reply to rturn3060:
That is a good idea Russell thanks for making that suggestion.
Fri, Aug 2, 2013 5:08 PM
