Cat sixty Ensign carburettor
cletracker
Send a private message to cletracker
Hi, helping a friend with his Caterpillar Sixty (ex. Doc Sheppard) and have a question about the Ensign carburettor. Looks like it´s missing the load needle and spring, does anyone sell new needles and springs? What is the correct model name of this Ensign carburettor?
Erik
Mon, Jan 21, 2019 7:08 PM
willwingo
Thank you received: 8
The Ensign model number is AAe. That model information is stamped on the rim of the upper flange.
I don't quite understand what is missing? The high speed adjustment needle and spring is under the knurled cap (top center) in the picture.
The scan below is from the Operator's Instruction Book for Caterpillar Sixty Tractor, 1931
[attachment=52432]carburetor page.jpg[/attachment]
[attachment=52433]operator instruction book cover.jpg[/attachment]
Mon, Jan 21, 2019 8:59 PM
cletracker
Reply to willwingo:
Thanks phildirt
There is no high speed adjustment needle and no spring under the knurled cap named "G" in your scanned photo, they are missing. Are there any reproduction needle and spring to get hold of?
/Erik
Mon, Jan 21, 2019 10:04 PM
cletracker
Reply to cletracker:
Thanks phildirt
/Erik
Please, can anyone tell me if and where I can find a new high speed adjustment needle to a Cat Sixty Ensign AAe carburettor?
Erik
Tue, Jan 22, 2019 2:44 AM
willwingo
Erik
Here is a picture of what you need.
The shaft is .125"
Should be an easy job for a tool and die maker. The spring only holds tension so the cap doesn't come off.
[attachment=52434]002.jpg[/attachment]
Tue, Jan 22, 2019 3:38 AM
cletracker
Reply to willwingo:
The shaft is .125"
Thanks!
Yes, that one should be easy to make now when I know how it should look.
/Erik
Tue, Jan 22, 2019 4:51 PM
