Cat paint hardener?
Cat paint hardener?
Showing 1 to 10 of 12 results
yieldmap
Send a private message to yieldmap
Hey all,
Does anybody use Hardener with the Cat paint? What mix?
It's kinda expensive, quote was $104/gal for the hardener.
Thanks,
Sam
Tue, May 19, 2009 9:07 PM
B4D2
YM, I know guys who have used it and it does make for a more durable finish. I don't think you need a whole gallon, unless you are painting a fleet of old iron. I know I have seen tractor paint at Farm & Fleet. The cans of hardener are on the shelf right next to it. They are usually 1 pint cans, and as I recall, you add it into 1 gallon. Good luck, and take pictures.
Tue, May 19, 2009 9:21 PM
Sasquatch
Thank you received: 5
Reply to B4D2:
I've never used Cat paint, but the DuPont I sprayed on my 5U has it. It didn't need much, the mix ratio was 4 parts paint, 8 parts reducer, and 1 part hardner. Different brands will have different ratios, though.
Tue, May 19, 2009 10:09 PM
yieldmap
Reply to Sasquatch:
I just found the paint section of the Shop Supplies catalog. It says on the hardener "for professional use only."
That's certainly not me!
Thanks,
Sam
Tue, May 19, 2009 11:17 PM
OzDozer
Reply to yieldmap:
Thanks,
Sam
In my experience, the hardener used in most industrial paints, is a methyl iso-cyanate compound. This is classified as an organic cyanide compound, and is extremely dangerous to inhale in even modest amounts.
It is recommended by all manufacturers, that full face breathing equipment be used with methyl iso-cyanate compounds .. unless you want to shorten your lifespan by a considerable degree, or end up with what is known as industrial asthma.
Either result is most unpleasant, and it pays to familiarise yourself with all warnings and recommendations, on stuff you want to spray around.
Tue, May 19, 2009 11:40 PM
Sasquatch
Reply to OzDozer:
When I started spraying paints with hardner I bought a pressurized hood and respirator from HobbyAir, it was a cheaper model but has worked great for the one or two times a year I paint. It's just an air pump with about 50 feet of hose that feeds the hood from a remote, clean air area. With the pressurized hood you don't even smell the paint, plus your eyes are protected. I also like to keep my arms and hands covered to avoid absorbing any chemicals through the skin. I usually wear a disposable cartridge type respirator when mixing the paint too, might be overkill but I think it's worth it.
Wed, May 20, 2009 12:20 AM
Cysco
Reply to Sasquatch:
I have been using Valspar Truck and Tractor Paint from my local Tractor Supply. They have the hardener in pints for about 10 bucks. Little pricey but I don't use that much.
Wed, May 20, 2009 12:26 AM
terrywelch_archive
Reply to Cysco:
Hardner is not a good thing to inhale. Use a good mask. A fresh air system is the best. What properties of the hardner do to a person is break down the membranes in your lungs. I have shot paint with hardner or activator for over 30 years and will not do it with out a good breathing system.
Wed, May 20, 2009 8:46 AM
OneWelder
Send a private message to OneWelder
Reply to terrywelch_archive:
Old school used " XIM" - spray a seal coat then mix a little in paint- too much and in time it would crack like glass and be so hard you could not sand it- not sure that they have it for newer type paints - ask about it at auto body supply store
Fri, May 22, 2009 4:21 AM
cdw
Send a private message to cdw
I use cat yellow with NAPA enamial reducer and hardner. 10 paint, 2 reducer, 1 hardner. If paint is a little thick you can use a little more reducer. It has worked well so far.
Fri, May 22, 2009 6:58 AM
bunkclimber
Send a private message to bunkclimber
if you want to use the hardeners in your enamel paints better get them now,I hear that within the next two years you'll need a EPA # to buy any and all activated enamels,polys,hardeners,reducers and such over the counter.You can substitute the isocyanate hardeners amongst brands but it's best to stay within manufacturers.I use the Valspar isocy hardener all the time with Dupont acrylic enamels with no problems.(Yes,I stocked up)altho the stuff does go bad with age,even in a new,sealed container..FWIW
Thu, May 28, 2009 11:21 PM
