Cat D8H Precups
Cat D8H Precups
Showing 1 to 10 of 17 results
mlauck1
Send a private message to mlauck1
Hello,
Started our D8H up today and the pre-cup blew out. From the look of the pictures, the bottom half is still in the machine? What I have doesn’t look broken, but there’s got to be threads to hold it in place correct? No glow plugs on this cat.
Fri, Feb 28, 2025 8:12 AM
Online
Thank you received: 45
Not all that uncommon to have a chamber separate at the furnace brazed joint. Usual repair involves welding a nut or bolt to the remaining section in order to unscrew the lower half.
Sat, Mar 1, 2025 12:51 AM
mlauck1
Thanks OM. After I get the other half out, could a good welding/machine shop repair the precup, or am I going to have to find another one?
Thanks again.
Sun, Mar 2, 2025 2:39 AM
Online
Reply to mlauck1:
Thanks again.
Get a new one...part # 9M8025 = 2P0483 = 7S5784
Sun, Mar 2, 2025 4:17 AM
Busso20
Thank you received: 22
OM did you wait some time before attempting to remove after welding? I was thinking heat expansion from weld then wait to cool/contract may help to remove thread end easier.
Sun, Mar 2, 2025 5:12 AM
Online
Reply to Busso20:
Yes, let it cool before removal.
Sun, Mar 2, 2025 8:19 AM
mlauck1
I got a good weld on a bolt, it’s TIGHT. It would be left hand thread would it?
Fri, Mar 7, 2025 1:17 AM
mlauck1
Reply to mlauck1:
Got it! Thought I welded the bolt to the block.
Fri, Mar 7, 2025 1:26 AM
mlauck1
Old Magnet, this cat doesn’t have glow plugs. The part number you gave me, is that precup for an engine with glow plugs?
Thanks again so much for your help.
Fri, Mar 7, 2025 2:20 AM
Wombat
Donor
Reply to mlauck1:
Glow plug pre cups fit the same no problem in using them, I think the older non glow plug pre cups may not be available anymore.
Wombat
Fri, Mar 7, 2025 3:05 AM
mlauck1
Reply to Wombat:
Wombat
Thanks Wombat. Will the same injector work?
Fri, Mar 7, 2025 3:24 AM
