Cat d6 9u starter info
Showing 1 to 10 of 13 results
mikewood869
Send a private message to mikewood869
Anyone happen to guess what model starter this is? It came off a d6 9u. There’s no tag and I’m not getting good part numbers off this thing. I’ve already put it on 24 volts just not in the pictures
Mon, Oct 6, 2025 10:54 PM
Thank you received: 62
Delco MT 40 I think is the model from back in the day. But I am not a expert by any means, so that is a educated guess.
Tue, Oct 7, 2025 5:01 PM
mikewood869
Ended up finding some numbers where the tag was.
Fri, Oct 10, 2025 11:34 PM
Thank you received: 78
That 1113740 is superseded by 1990453 (42MT 24v with 12 teeth straight - I assume that the D6 also uses a helical tooth arrangement so you'd want to buy that gear from ebay. Or are you continuing to use the 1113740?
Sat, Oct 11, 2025 3:12 AM
mikewood869
To be honest I don’t know yet, I’m gonna try another starter shop
Mon, Oct 13, 2025 12:32 AM
josh
Thank you received: 14
Could that part number be 1113746? That would be the correct starter for the 9U D6 and 7U D4 etc, cat part # 3L1227.
That appears to be the correct mounting and drive assemblies for those applications, and it would be 24V.
That's a nice looking starter, the drive looks new.
Mon, Oct 13, 2025 3:43 AM
mikewood869
Reply to josh:
The bendix doesn’t have much ware on it. The armature is junk. We’re going to see if it can be rebuilt or get a starter with the correct nose. I ended up taking it down to Hartford ct
Wed, Oct 15, 2025 1:39 AM
cr
Send a private message to cr
Thank you received: 25
If you can not find the parts to fix this starter, the next best option would be to replace it with a modern 42MT starter with the helix drive and the correct nose cone typically sold / built for the D4 and D6 u series starting engine (pony motor) to direct start conversions.
Wed, Oct 15, 2025 2:46 AM
Grow
Thank you received: 5
Great post. I have had my head in the books trying to sort out a d4 starter. The book shows to different starters that look alike from the outside. Casting numbers are the same yet the insides are not alike. The early starter has the pos connection on the end and the neg on the side. The later starter has the neg on the end and the pos on the side. If you really look close at the book, one of the starters has the post on the end that lools to be isolated with a bushing of some sort. Working off my phone sorry cannot post the pic as found in my d4 book
Wed, Oct 15, 2025 3:00 AM
Grow
This is two different starters I was talking about.
Wed, Oct 15, 2025 10:37 PM
Grow
Wed, Oct 15, 2025 10:41 PM
