cat 930 loader
cat 930 loader
jdtwocyl
Send a private message to jdtwocyl
i have a cat 930 loader without a serial number plate. is there another location were a serial number might be stamped. Also wondering if there are any gray wavy cat logo hats available.
Sun, Jul 13, 2025 5:32 PM
Thank you received: 40
Hi, jdtwocyl.
(I had to copy-n-paste that name to make sure I got it right.) There should be a serial number stamped into the metal under where the S/N plate was originally installed. Also. if you can find the engine S/N and Arrangement numbers, a Cat dealer should be able to back-track it to find it what frame # it went into.
Somebody else here who has had more to do with 930s might have more info for you.
Mon, Jul 14, 2025 9:53 AM
jdtwocyl
Thanks for the info. The engine serial number is there.
Mon, Jul 14, 2025 11:03 AM
