Cat 44A 5182
Cat 44A 5182
Showing 1 to 10 of 10 results
Dick Tucker_archive
Send a private message to Dick Tucker_archive
What Model and year model would SN 44A 5182 be? Also will this be a 24V or 12V system?
Mon, Feb 17, 2020 10:05 PM
That would be an early D6B, they were built from 1959 to 1967. 24V system
Mon, Feb 17, 2020 10:37 PM
bluox
Thank you received: 12
If it has a starting engine it should be 12 volt.
Bob
Mon, Feb 17, 2020 11:56 PM
Dick Tucker_archive
Reply to bluox:
Bob
Does this model have hydraulic track adjusters? Also are parts available for this machine?
Tue, Feb 18, 2020 2:01 AM
Reply to Dick Tucker_archive:
It may have, looks like a hole in the dirt shield to the grease fitting.
Tue, Feb 18, 2020 3:07 AM
Dizzel
Send a private message to Dizzel
Looks like there’s no pony so likely a 24v system. D6b should have hydraulic track adjusters. Mine does. Looks like I can see segmented sprockets so hopefully they’ve been upgraded. Lots of grouser. Definitely worth a good look
On second glance the sprockets may be just a large ring bolted on, the track pads look worn pretty good and the adjustment looks pretty far forward already. I see the pony exhaust hole. Not sure if the direct electric start d6bs had that. So quite possibly a conversion to direct electric start which wouldn’t be a big surprise. What’s the story? Does it turn? Is it yours?
Tue, Feb 18, 2020 3:59 AM
Dick Tucker_archive
Reply to Dizzel:
No it is not mine a friend found it. The guy that owns it does not know what if anything is wrong with it. It has been setting for 6 years. Going to try to start it this next weekend to see if it will run. Has oil on the dip stick with no diesel in the crankcase. The sprockets are welded on segments and the teeth are getting sharp.
Tue, Feb 18, 2020 5:18 AM
Is the oil level in the engine high? If so probably has water in it with the open exhaust. I would open the drain plug a little and check before starting it.
Tue, Feb 18, 2020 5:58 AM
bluox
The pictures are not real clear but looks like manual adjusters check if rod going into idler yoke is hex shaped.
Tracks / under carriage are pretty much total junk.
Bob
Tue, Feb 18, 2020 6:51 AM
Dizzel
Solid advice right there. Worth way more than what you paid!
Tue, Feb 18, 2020 9:39 AM
kittyman1
Reply to Dizzel:
- i'll second that as well Dizzel !:high5:
- i crack all drain plugs to see what's happening, water(1.000) and anti-freeze(1.036) show up before oil (.872)....:high5:
Tue, Feb 18, 2020 12:41 PM
