cat 30 coolant leak
cat 30 coolant leak
gibsonf5
Send a private message to gibsonf5
has anyone ever used stop leak in these old cats with good results that have packing for seals as opposed to regular lip seals? i have used it in other crawlers and tractors but never any with packing. i didnt know whether the stop leak may damage or harden or simply ruin packin. i am not trying to stop the slow, tiny drip that occationally comes from around pump shaft but trying to stop a few small leaks between radiator top and bottom tanks and core without taking all that apart. regards, eric
Sun, Aug 24, 2014 12:47 AM
3J1Bill
I have used stop leak with no problems. It will work the best on the lower leaks as a CAT 30 is a non pressurized system. I just used some in my CAT D2 # 3J2 to stop some drips at the bottom of the tank. 30 years ago I missed a ground squirrel and killed my 22 rad. with a perfect shot with a 16 gauge double barrel shot gun.:eek2: The replacement rad. had a few leaks and stopped them with stop leak. No leaks to this day.
Sun, Aug 24, 2014 10:06 AM
JasonPayneCrawlers
Reply to 3J1Bill:
I have used this a few times seemed to work very well for the price. I have a Cat ten that I just can't seem to stop it has a very small weep from time to time. Think this stuff works well when there is a larger hole so it can get into to clog
http://barsproducts.com/catalog/view/13-liquid-copper-block-seal-intake-radiator-stop-leak-1109/testimonials
Sun, Aug 24, 2014 10:11 AM
ol Grump
Reply to JasonPayneCrawlers:
I used to use AlumaSeal but now this is my choice http://barsproducts.com/catalog/view/15-liquid-aluminum-cooling-system-stop-leak-1186
Sun, Aug 24, 2014 6:49 PM
Reply to ol Grump:
Packing on the pumps seem to dry out and weep, then stop as they swell/saturate again from running.
Leaky gaskets may leak awhile till the stop leak/ bars leak works its way through the system!
Sun, Aug 24, 2014 8:35 PM
gibsonf5
Reply to drujinin:
fantastic. thanks guys. i was just reluctant to use it with packing for shaft seals. gonna give it a shot and see what happens. leaks are so small that stop leak should do the trick, eric
Sun, Aug 24, 2014 11:56 PM
