Cat 22 has me stumped
sbybee
Send a private message to sbybee
I got the magneto back, took the valve cover off, pulled spark plugs, brought #1 one round installed mag lined up the short tooth in center of window tightened everything up, wire brushed plugs and holes, cleaned rotor, checked for spark on all four plugs, installed plugs checked firing order, checked fuel flow and fuel pump unhooked intake filter, drained carb and no start! Don't like to but used a little ether, no go. Put my hand over intake and lots of suction and a little smoke and kick but no start. I have compression, no adapter for a gauge, I have good spark, good ground. Even removed ground wire from mag. So just before I gave up and pulled the tarps I brought #1 around, pulled cap checked rotor and it didn't seem right so pulled little brass plug and my short tooth mark (white outed) wasn't in the middle of window. Looks like 2 to 3 teeth off? The magneto shop pulled it apart to double check marks and said it was right on.?????? I bought a Eissman manual and its a great copy and shows how to install it. help thanx steve
d2, 2n, 8n, 4000, cub cadet 169, massey compact, home made tractor, and more
Exact center of California
Fri, Mar 11, 2016 8:41 AM
bruce oz
hello , you need to trip the advance on the magneto to do the timing ,your book shpuld tell you how to trip it , bruce oz
Fri, Mar 11, 2016 9:48 AM
sbybee
Reply to bruce oz:
I wondered about that. The book made it seem like that was for setting the points. I found the hole but never did get it to trip. I'll try harder tomorrow. thanx steve
Fri, Mar 11, 2016 12:20 PM
Reply to sbybee:
Steve I wonder if something's stuck in the trip hole? My vague understanding is that a pin can be fitted to lock the trip out for timing - if a piece is still stuck in there it might be preventing the trip from working
Sat, Mar 12, 2016 2:09 AM
| Hartley - South Australia
