Cat 12E Power Steering Pump
big harold
Send a private message to big harold
I have a Cat 12E 38E serial.
The power steering coupling has let go.
I can remove the coupling from the pump, nut on the shaft.
I can't see how the coupling on the pto tover is removed maybe just screwed on.
Anyone have a parts breakdown.
Mark
Tue, May 15, 2018 4:39 AM
Looks like the coupling is simply slid onto the splined shaft with a pin or ring in the center to keep it from going too far forward or back. It might actually be pinned to the drive shaft in which case you would unbolt the front of the power control drive box and pull the front bearing cup off exposing the whole shaft extension and coupling.
I am looking at 99E parts book.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timešŸ˜„
Tue, May 15, 2018 9:43 AM
big harold
[quote="ccjersey"]Looks like the coupling is simply slid onto the splined shaft with a pin or ring in the center to keep it from going too far forward or back. It might actually be pinned to the drive shaft in which case you would unbolt the front of the power control drive box and pull the front bearing cup off exposing the whole shaft extension and coupling.
I am looking at 99E parts book.[/quote]
Thankyou.
Have you a drawing of the coupling that goes on that shaft?
There should also be a seal on the extension.
Mark
Tue, May 15, 2018 11:33 AM
oldbeek
Reply to big harold:
Thankyou.
Mark
There is just the splined coupler. Spline on hydraulic pump and spline on the control tower shaft. There is no seal on hydraulic pump end of shaft.The hydraulic pump seals that end of the shaft and housing. Had mine apart last year to reset the timken load on the bearings. Coupler should slide right off the lower control shaft once the hydraulic pump is removed.
Tue, May 15, 2018 12:06 PM
Sorry, I have never had one apart. The parts book picture is all I have I think. Typically the loose double female coupling has a pin or snapring in the center to keep it centered over the space between the ends of the two shafts. If it doesn't want to slide off the shaft it could be pinned to the shaft but I think it is more likely partially stripped out and in a bind. I bet it will tap right off once you remove the housing extension and can get a swing at it with a hammer.
Tue, May 15, 2018 12:19 PM
| ā€œDe Domelaarā€ Gebr .V.d. Heiden Domelaarsweg 3 7475 MARKELO Netherlands
