Brought home a D4C 40A
bursitis
I brought home another D4. This time it's a D4C 40A that's going to need some tlc. I'm new to this type of D4 as it seems to be alot like the 7U 6U but not like the D4D. Books on the way via ebay.
Mon, Apr 21, 2025 1:11 PM
Thank you received: 287
That is fantastic Bursitis: What is your serial number? I have 3 C series here, all are 40A prefix; 2 top seat and one orchard.
I call it the Achilles heel of the 330 engine; the long water pump pulley snout...it is long and heavy, and the bearings can get sloppy. Make sure it is nice and tight. Aside from the water pump, I have never had any issues getting parts or have problems with mine. Some will say the C series wasn't any good because it was only produced 3 years... I heard they overheat because of the small radiator...again, many times from the mouths of folks that have never owned one!
Post some photos of your new gem please. Congratulations. JM
Mon, Apr 21, 2025 2:45 PM
bursitis
Thanks juiceman. The serial is 40A3038 and under that number is a capital C. It appears to have always been direct electric start has the cat straight blade and a 5 shank ripper on the back. The main clutch is oil type and needs adjusted because it doesn't snap over. I suppose the steering clutches are the dry type??? It needs the right side final drive overhauled though. It is a seat tank standard tractor though. I am unfamiliar with the D4C. Your right about that water pump.
Mon, Apr 21, 2025 5:04 PM
bursitis
Trying to attach a picture
Wed, Apr 23, 2025 1:08 PM
bursitis
Again
717-33550-1960
Wed, Apr 23, 2025 1:12 PM
bursitis
Well poo! I'll figure it out but right now i can't get the picture to attach.
Wed, Apr 23, 2025 1:13 PM
Thank you received: 140
Hi, bursitis.
I have had the same problem - found that attaching the photo a second time before trying to post seemed to work.
Wed, Apr 23, 2025 1:43 PM
bursitis
Wed, Apr 23, 2025 2:22 PM
bursitis
I sent the photo to a text to myself and then copy that photo from text and attach here. It works
Wed, Apr 23, 2025 2:23 PM
