Wtb electric start for D4 5t pony engine
Showing 1 to 10 of 12 results
43gpw
Send a private message to 43gpw
Looking for elect. start for pony engine D4 5T #6974.
Thank in advance
Russ
Wed, Feb 22, 2017 7:46 AM
NIK O.
Send a private message to NIK O.
[quote="43gpw"]looking for elect. Start for pony engine d4 5t #6974.
Thank in advance
russ[/quote]
sir, if u like, have 120 volt motor & belt, that sits on fender of d-4, spins pony...sold d-4, $50 gets motor, pivot, belt, switch...works well...be blessed, grateful, prepared, nik viet vet...ate 0 6 7 ate 7 fore nin 6 0
Sun, Mar 5, 2017 8:34 AM
43gpw
Reply to NIK O.:
Thank in advance
russ[/quote]
NIK O.
Thank you for the offer, 120 volt in the middle of wilderness won't work for me. Will have to stick with the rope for now.
Great idea though
Say, did you mean 12 volt instead of 120 volt ?
Russ
Sun, Mar 5, 2017 10:50 AM
NIK O.
Reply to 43gpw:
NIK O.
Great idea though
Russ
[quote="43gpw"]NIK O.
Great idea though
Russ[/quote]
110/115 volt
Mon, Mar 6, 2017 4:45 AM
Greg P
Send a private message to Greg P
Reply to NIK O.:
Great idea though
Russ[/quote]
110/115 volt
Try using an old aluminum 3-5 hp engine off of a lawnmower or edger. I used one with the handle attached to the head bolts and bolted to a small plywood base. Just set it on the fender and spin the pony with a v-belt. It works like a charm....
Tue, Mar 7, 2017 12:44 AM
yancy44 mag
Send a private message to yancy44 mag
Reply to Greg P:
BEAT YOU TO IT A COUPLE OF DAYS A GO LOL WE ARE JUST TRYING TO HELP A BUDDY OUT I HAVE USED A 3.5 HP BRIGS AND AT IDLE YOU PUT THE BELT ON AND THROTTLE UP WITH A PULLEY AND A AUTO BELT AND WHEN SHE STARTS IT TOSSES IT IN THE FLOOR BORD IN THE BREAK HOLE IT WILL START MY D2 IN -30 HERE IN MT AS WELL AS THE D4 EASIER THAN THE PAIN IN THE PONY WITH THE BRIGS SHE WILL FIRE RIGHT UP YOU ARE SPINNING IT SO FAST I NEVER HAVE NOT HAD THEM START HAD THE 3J1810 BEEN SETTING 8 MOS AND FIRED HER RIGHT UP SHE WENT NOW !!!!!!! ANY WAY WE WERE THINKING ALONG THE SAME LINES LOL I ALWAYS TAKE MINE WHEN I AM GOING TO LOOK AT ONE THAT,S BEEN SETTING A LONG TIME THE LAST D2 I GOT HAD SAT 15 YEARS BLEW THE FUEL TANK OUT WITH MY COMP WAY OUT IN THE MIDDLE OF NOW WHERE LAND PUT GAS IN THE TANK WRENCHED STUFF TIGHT TO STOP THE BIG LEAKS AND SPUN IT OVER TO GET OIL IN EVERY AND TURN THE GAS ON AND SHE FIRED RIGHT UP THEN POPED THE COMP THE COMP RELEASE AND SPUN THE ENG GOT OIL AND LIGHT SMOKE AND FLIPPED IT BACK AND THE MAIN FIRED RIGHT UP THE FELLOW I BOUGH IT FROM DID NOT BELIEVE I GOT IT DONE IN LESS THAN 4 HRS AND DROVE IT TO THE SHOP TO LOAD ON MY TRAILER I HAD TO PRESSURE WASH IT OFF BEFORE THE LONG TRIP DOWN THE HIGHWAY LATER GUYS !:crazy:
Tue, Mar 7, 2017 2:49 PM
rax200
Reply to yancy44 mag:
hi All, Yes i do not mind at pulling the rope on my old D4's but when they get stubborn i use this, it was made out of a Hillman starter.
Tue, Mar 7, 2017 4:52 PM
43gpw
Reply to rax200:
Great ideas to ponder, thanks for responding about this subject
Thinking more along the lines of of building a setup like OEM would be.
I see where something that is portable, for those out of the way treasures, would be a blessing.
Or bring along the grandson, to be my "starter".😀
Russ
Tue, Mar 7, 2017 7:45 PM
old-iron-habit
Hello, Had not heard from you for a while and was wondering. Good to see you back on the board.
Roger
Tue, Mar 7, 2017 8:33 PM
old-iron-habit
Reply to 43gpw:
Russ
The first D2 that we ever owned when I was a kid had a six volt starter on it bolted to a homemade bracket to the right of the shift lever. The starter body faced the operator in the seat. I am thinking they mounted it on the right to turn the pony the correct way with the starter reversed. It had a ring gear added to the pony and to engage you just pulled the bendex in by an actuating lever on the starter. We never had a battery in it. We just connected jumpers when we started it. I believe it was an old Ford starter of the era when you stepped on the starter pedal to engage. It actually worked very well and with 12 volt connected it spun the pony at a super cranking speed.
Tue, Mar 7, 2017 8:41 PM
STEPHEN
Reply to rax200:
I like it. If there was a towtruck for old cats that would be in the toolbox.
Tue, Mar 7, 2017 9:15 PM
