Wtb d2 pinion shaft
Wtb d2 pinion shaft
Showing 1 to 10 of 10 results
JoeWestfall
Send a private message to JoeWestfall
I am looking for a D2 transmission pinion shaft.
PT # 3K3540. Anyone who would like to sell one
would be appreciated.
Joe Westfall
Fri, Apr 11, 2014 7:24 AM
hiwide15
Send a private message to hiwide15
What is serial number? I am parting 5 this weekend. Just prior to longer trans case.
Ron Meeder 716-753-0056.
Fri, Apr 11, 2014 8:28 AM
bboaz
Reply to hiwide15:
Do you have a radiator core (5F2141) for a 4U (4U421😎 D-2 from the machines you are parting out? Shipping would be to Saint Robert, MO 65584.
Fri, Apr 11, 2014 7:47 PM
gemdozer
Thank you received: 25
Reply to bboaz:
I am still have a pinion shaft 3k3540 but is't in very good condition
Fri, Apr 11, 2014 8:34 PM
JoeWestfall
Reply to hiwide15:
[quote="hiwide15"]What is serial number? I am parting 5 this weekend. Just prior to longer trans case.
Ron Meeder 716-753-0056.[/quote]
Hi Ron,The actual serial number in this case does not matter.
This pinion shaft is part of a Caterpillar change up. Early D2s
that had a 6B9857 pinion and 6B9991 bevel gear changed up
to a 3K3541 bevel gear and 3K3540 shaft. They called it a
coarse pitch bevel gear and pinion,to give longer service life.
I have the 3K3540 bevel gear just need pinion shaft.
Any older 3J, 5J,4U,5U may have been changed up in its life.
Part # will be stamped on gear end of pinion shaft.
Thanks Joe Westfall
Fri, Apr 11, 2014 8:45 PM
JoeWestfall
Reply to gemdozer:
Hi, What is wrong with it?
Joe Westfall
Fri, Apr 11, 2014 8:46 PM
hiwide15
Reply to JoeWestfall:
Joe Westfall
Yes I have a rad core or complete Rad. Ron
Sat, Apr 12, 2014 12:10 AM
gemdozer
Reply to hiwide15:
My pinion have no broken teeth but have some small smashs on and maybe some small metal pieces pass betwen gear and pinion.
Sat, Apr 12, 2014 1:05 AM
Thank you received: 77
Reply to gemdozer:
Ron, I need a replacement pony air cleaner oil bath cup for a U-series - I ran over mine dagnabit....Also in need of side covers and a good toolbox for under the seat (oh and a good battery box and innards)
Sat, Apr 12, 2014 4:32 AM
JoeWestfall
Reply to gemdozer:
[quote="gemdozer"]My pinion have no broken teeth but have some small smashs on and maybe some small metal pieces pass betwen gear and pinion.
[email protected][/quote]
HI, Does your pinion have that PT# 3K3540
marked on it? Can you send a picture of it
please.
Joe Westfall
Sat, Apr 12, 2014 4:52 AM
JoeWestfall
Reply to hiwide15:
Hi Ron,
Were you able to strip down your machines yet?
Still interested in 3K3540 pinion shaft and cage.
Joe Westfall
Mon, Apr 14, 2014 8:39 PM
