Hi team
my buddy needs the main clutch throwout collar and yoke for his 5U. Previous owner replaced it with a ball bearing for some reason. Anyway, the best I can tell, the part numbers are:
7B5773 - collar - the throwout collar
4B3505 - collar assembly - the bronze thrust collar that the yoke connects to
4B3446 - pin - stud that spins the throwout collar with the "spider" (also called a collar assembly in the parts catalog)
7B5714 - pin - connects the links between the throwout collar and the spider - need possibly eight of these
4B3817 - yoke - to disengage the clutch
1B8714 - key - for yoke
Shipping to 14534 please
Hello, check out the flywheel clutch coller assembly I got available, still much new and in good working condition.
Will take $100 shipped to your zip (will need your address)
Hi ATV, I'll send you a private message
I responded back.
Thanks.
Hello Neil, I’m yet to get a response from you.
If you are still interested getting the Clutch coller assembly.
No respond from you !
ATV_trailer just curious did you check your inbox here on the website if you’re a member?
Hi ATV, no need to panic, I've had a few things going on which take priority over what is to me a hobby. Are you in a particular hurry to sell the part?
