WTB - D2 early 5U/4U and J-series clutch spider and yoke
Thank you received: 78
Hi team
my buddy needs the main clutch throwout collar and yoke for his 5U. Previous owner replaced it with a ball bearing for some reason. Anyway, the best I can tell, the part numbers are:
7B5773 - collar - the throwout collar
4B3505 - collar assembly - the bronze thrust collar that the yoke connects to
4B3446 - pin - stud that spins the throwout collar with the "spider" (also called a collar assembly in the parts catalog)
7B5714 - pin - connects the links between the throwout collar and the spider - need possibly eight of these
4B3817 - yoke - to disengage the clutch
1B8714 - key - for yoke
Shipping to 14534 please
Wed, May 13, 2026 6:40 PM
ATV_trailer
Send a private message to ATV_trailer
Hello, check out the flywheel clutch coller assembly I got available, still much new and in good working condition.
Will take $100 shipped to your zip (will need your address)
Thu, May 14, 2026 11:07 AM
Hi ATV, I'll send you a private message
Sat, May 16, 2026 3:26 AM
ATV_trailer
I responded back.
Thanks.
Sat, May 16, 2026 4:59 PM
ATV_trailer
Hello Neil, I’m yet to get a response from you.
If you are still interested getting the Clutch coller assembly.
Mon, May 18, 2026 12:44 AM
ATV_trailer
No respond from you !
Tue, May 19, 2026 9:48 PM
clayton
Thank you received: 25
ATV_trailer just curious did you check your inbox here on the website if you’re a member?
Wed, May 20, 2026 10:21 AM
Hi ATV, no need to panic, I've had a few things going on which take priority over what is to me a hobby. Are you in a particular hurry to sell the part?
Thu, May 21, 2026 12:27 PM
ATV_trailer
Alright I will await to here back from you so we can conclude on the sales.
Sat, May 23, 2026 4:43 PM
