WTB Cat thirty transmission oil thrower gear
Showing 1 to 9 of 9 results
Nospark015
Send a private message to Nospark015
  Good evening:
  We need the transmission oil thrower gear # 1B1586 for a Cat Thirty. It lives in the bottom of the transmission case and somehow ate a bolt. Any help would be greatly appreciated!
Thu, Sep 15, 2022 7:50 AM
logjamesx
Send a private message to logjamesx
Have you checked with galetech
Fri, Sep 16, 2022 1:20 AM
Nospark015
Hello:
The oil thrower gear he had was sold. Any other leads would be greatly appreciated! I suspect any stray object that falls into the gear case will take out that gear.
Sat, Sep 17, 2022 2:39 PM
Cysco
 [attachment=68946]Cat Thirty Trans Gears.jpg[/attachment]I am assuming you already found the gear since I received no response from a PM sent to you.
Tue, Sep 20, 2022 7:55 PM
gvoerm
Send a private message to gvoerm
Reply to Cysco:
I have a parts transmission I could pull one out of. Let me know if you are interested.
Grant
Wed, Sep 21, 2022 12:48 AM
Nospark015
Reply to gvoerm:
Grant
Hello Grant:
  I have not found one yet.  I did not see your message for some reason. Please let me know what you need for it and where you are. I will likely need more parts as this project goes. The pipe that supports the oil catch cup for the reverse idler gear shaft rotted off and the cup went through the gear.
Best regards,
Jim
Wed, Sep 21, 2022 8:00 AM
gvoerm
I pulled out the oil sling gear from my 30 if you are still interested.
Mon, Oct 3, 2022 8:17 AM
Nospark015
Reply to gvoerm:
Hello Grant:
  Yes I am still interested. Please let me know the cost and shipping. The sad part is that the transmission it came from is probably in better shape than mine. This tractor was used for logging and ridden hard and put away wet. I have no idea how that gear got so torn up unless it ate a nut or bolt.
Mon, Oct 3, 2022 3:22 PM
gvoerm
Reply to gvoerm:
What is your address or town at least so I can get a shipping quote?
Tue, Oct 4, 2022 9:23 AM
Nospark015
Reply to gvoerm:
Hello Grant:
  In case my last message did not reach you we are located at 800 Ne 35Th Ave, Camas, Wash. 98607.
Mon, Oct 10, 2022 9:45 AM
