Wtb 933 transmission pinion shaft
JoeWestfall
Send a private message to JoeWestfall
Looking to buy a 3K3540 pinion shaft.
It was used in 933 trackscavator serial # 42A753-42A2105
This pinion shaft will have 11 teeth on it.
Any information leading to one,would be greatly appreciated.
Joe Westfall
Thu, Oct 20, 2016 8:45 PM
gemdozer
Thank you received: 25
I had 1 pinion shaft on rack for 933 serie 42a and I check if am still have it
Fri, Oct 21, 2016 12:40 AM
gemdozer
Reply to gemdozer:
I check yesterday for the pinion shaft with no luck am gone recheck on other racks
Fri, Oct 21, 2016 6:14 PM
gemdozer
Reply to gemdozer:
I recheck today for the pinion shaft 3k3540 but no luck I just found the bevelgear 3k3541
Sun, Oct 23, 2016 10:08 PM
JoeWestfall
Reply to gemdozer:
Thank-you for checking your stock.
I am not having any other luck on this shaft.
Joe Westfall
Tue, Oct 25, 2016 6:02 AM
