WTB #2F39 track adjuster nut
Breadler
Hello,
l am looking to find two usable #2F39 track adjuster nuts for a D2-5U. I was going to purchase new ones, however Holt says they are out of production.
thanks much,
Breadler [attachment=77603]7E7DAA02-112C-408A-8390-CE4752AF6E86.jpeg[/attachment]
Mon, Sep 16, 2024 10:09 AM
Thank you received: 31
Check the thread pitch, it could well a standard thread. Cat got off like other manufactures but don't tend to have to many none standard threads..
Mon, Sep 16, 2024 11:25 PM
Thank you received: 32
Reply to Ray54:
Unfortunately it's not just a plain nut - it's elongated, has a boss to stop axial movement, and has three splits in it so that those two bolts you see adjacent to it in the diagram can clamp down to lock it in place. A new one could be made by a competent machinist, but I think if he contacts some of the parts yards, they'll find him a good used one. There are plenty of carcases out there
Tue, Sep 17, 2024 7:40 PM
side-seat
Thank you received: 11
Are the treads wiped out on the adjuster bolt? Those nuts are cast iron I believe and should hold up better than the steel bolt.
Big job replacing the bolt in the spring assembly.
Need pictures showing the condition .
Tue, Sep 17, 2024 8:59 PM
Reply to side-seat:
Mine was fully rusted out but the previous owner apparently never cleaned the track gear off each day. I got a good used one from Dana at Florin - those days are over sadly
Wed, Sep 18, 2024 12:01 AM
BrianSnavely
Send a private message to BrianSnavely
I have two new track adjuster. Call m at 717 826 4800. I am in Pennsylvania. Brian Snavely
Thu, Sep 19, 2024 1:38 AM
