WTB 1988854 DELCO REMY
projectanavita
Send a private message to projectanavita
My order was canceled by the only source I could find in the US for this part number. Trying to convert Brutus to electric start so I can use him this year on our house build. Are there other parts I can use in place of this with my D47U ?
Wed, May 3, 2023 3:57 AM
Thank you received: 60
I don't know where your shopping but Delco 1988854 is a good number and available.
You can also use a 1988748 which is six hole indexing instead of twelve.
May make a difference depending on which lever housing the starter has.
Sun, May 7, 2023 12:21 AM
projectanavita
jit truck parts has both listed items out of stock on backorder.
find it parts, no stock available both items
sadler powertrain, no stock first item, no mention second item.
source 1 parts center may have the second item you provided ... will have to order to find out as the last place I ordered the original part number from with 12 indexing points had it "in stock" till I ordered :/
Do you know of a place that has the 12 indexing part in stock?
Mon, May 8, 2023 6:49 PM
projectanavita
Reply to projectanavita:
Vendor I ordered from, alternative part 6 indexing, just called to say they are out of stock and deloc can't give them a timeframe to when it will be in stock ...
Still looking for this :/
Wed, May 10, 2023 10:53 PM
projectanavita
Contacted George Scott to get one of his machined head units ...
Thu, May 11, 2023 9:02 PM
Got a picture? What does a machined head look like?
Is that a standard SAE 3 head that has been hacked up to give pinion clearance???
Sat, May 13, 2023 7:01 AM
| Kingaroy, Queensland
