Wanted turbo charger kit to fit D6 9U
Showing 1 to 10 of 29 results
earthmover07
Send a private message to earthmover07
I saw a video on YouTube with a D6 9u that was turbo charged and I would love to turbo charge my tractor . I know they didn't come factory with a charger but I wasn't sure if some company like M&W didn't make one. Any thoughts and suggestions would be greatly appreciated. Thanks
Wed, Apr 17, 2013 12:12 AM
D4C Charlie
Send a private message to D4C Charlie
Yea they did. This is in a high serial# 8U parts book, couldn't find my 9U but they are the same engine. There are different turbos and oil lines and a different air filter.
Wed, Apr 17, 2013 2:41 AM
earthmover07
Reply to D4C Charlie:
Do you by chance have the part # for that whole set up?
Wed, Apr 17, 2013 7:17 AM
D4C Charlie
Reply to earthmover07:
Parts book says 7H505 is factory instalation only. 7H4201 consists of all parts necessary to convert a standard tractor to a turbo tractor is available. Hope this helps. Charlie
Wed, Apr 17, 2013 8:48 AM
earthmover07
Thanks Charlie I really appreciate it brother.
Wed, Apr 17, 2013 11:06 AM
Chad Poe
Send a private message to Chad Poe
Hey, was just wanting to know how much hp turbo will give d6 9u plus what tractor was caterpillars first to have factory tufbo? Chad Poe
Wed, Apr 17, 2013 4:47 PM
Woody
Send a private message to Woody
Location: 5205 Thousand Springs Drive, Ammon Idaho 83406
Reply to Chad Poe:
Chad,
Late model SN#28,000 series 9U D6's were availble with a turbo. These would have been 1959 model year machines just prior to the introduction of the D6B which could be ordered with a Turbo. The D6C came standard with a Turbo, different engine arrangment than the D6B.
Halton Cat out in Oregon used to build a kit for the 9U's, not sure if they are still availble or not. In addtion to the turbo some guys added the gradder kit fuel pumps for more horsepower. Western States Cat also use to build a turbo kit, but that was some time ago. Having the tractor with the turbo will make considerable difference power wise. What you will need to be a where of is that it will build more heat if your working it hard, best to keep a close eye on the temp guage. Some guys added oil cooling to the bottom of pistons when they added the turbo.
There are several 9U's running in Eastern Washington, Oregon and Northern Idaho with Turbo's. You might find one for sale.
Woody
Thu, Apr 18, 2013 4:23 AM
Thank you received: 46
Reply to Woody:
Chad,
Woody
The standard turbo "grader package" on the D318 came out with the #14 model 78E & 64C graders. Was rated for 150 hp. The engines were considerably modified to accomodate the hp.
The "Northwest Turbo packages" were more for modification of regular D318 engines where fuel economy was more desirable than the slight gain in hp.
Here is the blurb in the Halton package:
Don't think any are available new anymore.
Thu, Apr 18, 2013 5:21 AM
earthmover07
I've looked everywhere all over the USA trying to find a manifold and I'm having no luck, would anyone have any idea of someone that might have one?
Thu, Apr 18, 2013 10:51 PM
naylorbros
Thank you received: 13
If you are looking for just the stardard exhaust manifold contact Rosewood Machine and Tool.
Thu, Apr 18, 2013 11:23 PM
earthmover07
Reply to naylorbros:
Where are they located?
Thu, Apr 18, 2013 11:52 PM
