Wanted R2 engine head CASH PAID
Showing 1 to 10 of 18 results
jcavhpd
Send a private message to jcavhpd
Gentleman I am in the market for a good used head that has no cracks in it, I have a beautiful crawler that I found to have a bad head. I use the tractor for sugaring so I'll be in a bind once the snow starts getting deep up here in Connecticut. I'm willing to pay handsomely for a fellow to put in the work of pullin the head off a machine. I am additionally interested in any other R2 engine or chassis parts depending on what they are. My cell is 860-398-8929 ask for John.
Fri, Oct 21, 2016 10:17 AM
joman
Send a private message to joman
John,
What year is that tractor? Is that a D3400 engine?
Joe
Fri, Oct 21, 2016 6:01 PM
STEPHEN
Reply to joman:
John,
Joe
[quote="joman"]John,
Joe[/quote]
G3400 or is it 3400G?
Fri, Oct 21, 2016 7:13 PM
Reply to STEPHEN:
Joe[/quote]
It is my understanding that the 3400G and D3400 use the same basic head.
Sat, Oct 22, 2016 12:49 AM
WyoCat
That's correct. He is looking for the gasoline head.
Chad Enyeart
Sat, Oct 22, 2016 2:18 AM
Reply to WyoCat:
Yes, spark plugs are the difference. Component parts may interchange.
Sat, Oct 22, 2016 2:26 AM
wimmera farmer
Thank you received: 10
Combustion chamber would be larger on the petrol kero to get compression ratio a bit lower than the diesel.
Sat, Oct 22, 2016 3:26 AM
chuckb
Reply to wimmera farmer:
he needs a 6 G thirty or R4 head some graders had the same engine i have a couple but they are for future projects
Sat, Oct 22, 2016 6:04 AM
Reply to chuckb:
We're talking about an R2 with 3400G engine used on (4J,6J s/n)
Sat, Oct 22, 2016 11:55 AM
chuckb
i am sorry i sure went off base on this one is this the same head that would be on the 22 Twenty TWO crawler?? if so there should be ample available
Sat, Oct 22, 2016 9:43 PM
Lance Jones
Reply to chuckb:
Hi Team , the R2 Engine has a Number of Parts common to the J Series D2, Head is definitely Different and is Not same as 22. Liners are same basically but have Chamfer at top to reduce Compression . there seems to be several different Intake manifolds , ,some would be for Kerosene
Sun, Oct 23, 2016 4:46 PM
