Wanted: Pony motor fuel lines D2/D4
seyser
Thank you received: 60
Wanted: Fuel lines for the starting engine on my U series D2. Need complete lines from tank to carb including good shutoff valve.
Thanks,
Jeremy
Mon, Apr 29, 2024 8:38 PM
JesseR
Send a private message to JesseR
Have you still got your old lines? My lines are all in pretty bad shape too and I was planning on just reusing the hose ends and just drilling the pipe out / brazing in new pipe. The shutoff valve on mine was broken also so it is currently sitting at the local jewlers who are going to weld it back together using 12carat gold (gold alloy so it is strong). I couldnt think of anyone else that would be able to weld something that intricate other than a jewellery maker.
Might not be of help but some ideas none-the-less.
Mon, Apr 29, 2024 9:21 PM
seyser
Reply to JesseR:
The previous owner removed them.
Mon, Apr 29, 2024 9:28 PM
JesseR
Reply to seyser:
In that case, If you need me to measure up a hose end on mine so that you can turn up some new ones in the lathe let me know and I will do a drawing.
Tue, Apr 30, 2024 6:38 PM
Thank you received: 78
Reply to JesseR:
You can buy the nuts and ferrules from Cat still - I bought some last year for my buddy's HT-4 which uses basically the same lines. If you were to get some brake line in that size, you could just bend, make, and solder your own
Wed, May 1, 2024 11:57 PM
