Are they the same as 9u D6 used or are they different? Part number for D6 is 4f6525.
I believe they are different. Grader was set up similar to the D318 stationary engine with a different pump and oil pan. Dozer was different to account for slopes and inclines. I could be wrong, however this was my understanding.
What's the s/n of the 8T????
The D6 oil pan should't fit on 8t grador
Serial # 8t10111, I think the earlier model 9U will work. Correct me if I am wrong? Prob. not because of the mounting to the differential.
Yes you are correct
The oil pans are not the same.
The early 8T uses a 4F7084.
The early 9U uses a 4F6525
