wanted gas fifty fuel pump
Showing 1 to 6 of 6 results
saskfarm
Send a private message to saskfarm
Hey everybody, needing a gas fifty fuel pump. Let me know what you've got.
thanks
Wed, Jul 8, 2015 10:40 AM
chriscokid
are you needing the entire pump or just a rebuild kit?
Thu, Jul 9, 2015 1:47 AM
saskfarm
Reply to chriscokid:
Yes, I need the whole pump assembly. It's totally missing from the tractor
Thu, Jul 9, 2015 11:49 AM
STEPHEN
Reply to saskfarm:
I think the body of the pump is the same as used on the 22, just a different arm. 22 pumps are easier to find and making an arm might not be that hard.
Thu, Jul 9, 2015 11:01 PM
saskfarm
Reply to STEPHEN:
I'll have to check out the 22 pump thanks. Does anyone know the part number for the 50 pump assembly?
Fri, Jul 10, 2015 8:11 PM
STEPHEN
Reply to STEPHEN:
I looked over my 50 and 22 fuel pumps, the bodies are identical. The 50 arm is slightly longer and more curved.
Sun, Jul 12, 2015 5:20 AM
terrywelch_archive
Reply to STEPHEN:
You are right the pumps are the same but the arms for these are hard to find the correct one. I bought 4 pumps before I got the correct arm.
Good Luck
Terry
Sun, Jul 12, 2015 6:17 AM
