Wanted: Fan pulley for D-6 5R
Showing 1 to 10 of 12 results
Shovelman
Send a private message to Shovelman
Looking for a good used fan (water pump) pulley for my D6 5R with the D4600 engine. The part numbers of the pulley halves are 7B203 & 6B7367.
I can be contacted at 860-482-three six zero zero
Thanks,
Scott
Tue, Jul 28, 2015 3:07 AM
Dozerman51
Hello, There,
Go to the Machinery Trader website. Scroll down to the "Parts for sale" section and in the search box punch in the numbers you have. Lot's of places have what you are looking for.👍
Tue, Jul 28, 2015 3:48 AM
rmyram
i have a pump off a d6 9u, not sure if the sheaves are the same or not, do not have parts book here to verify. the serial number was 9u 4620. also where are you located?
Tue, Jul 28, 2015 3:58 AM
josh
Thank you received: 13
Reply to rmyram:
6B6367 and 7B203 were only used on the D4600 and G4600.
Tue, Jul 28, 2015 5:41 AM
gemdozer
Reply to josh:
I check tomorrow morning but should have one 7b203
Tue, Jul 28, 2015 6:01 AM
gemdozer
Reply to gemdozer:
I just check my pulley and part number on is 7b5143 use on 4600 motor 5r1 to 5515 and 7b203 is use on same serie 1 to 5515
Tue, Jul 28, 2015 11:23 PM
Shovelman
Reply to gemdozer:
Thanks, gemdozer. My tractor's serial is 5R3396 The Cat parts book I have covers serials 5R1 to 5R4100, which calls for a 7B203 hub and 6B7367 rim.
I called Cat, and both 6B7367 and 7B5143 were showing as good numbers (no supersessions) but are NLA.
Where did you find the 7B5143 number - on the pulley hub or the rim?
Regards,
Scott
Wed, Jul 29, 2015 2:09 AM
gemdozer
Reply to Shovelman:
Regards,
Scott
I am sorry it is a second mistake today the 7b5143 is crankshaft pulley and I recheck tomorrow for water pump pulley .SORRY
HECTOR
Wed, Jul 29, 2015 4:39 AM
rmyram
part numbers for a 9u are completely different so my parts will not work for you. the numbers you have listed are correct for a 5r/4r
Wed, Jul 29, 2015 6:44 AM
old-iron-habit
Reply to rmyram:
I have a 4600 power unit in the shed with what I believe is a good waterpump arraignment on it. Not sure if powerunit is the same as a crawler.
Wed, Jul 29, 2015 8:37 AM
gemdozer
Reply to old-iron-habit:
I have the pulley 7b203 and the parts number is on hub and 6b7367 number is on the ring belt pulley adjustement
Wed, Jul 29, 2015 10:31 PM
