wanted D8H 46A track chain
Showing 1 to 9 of 9 results
au7edd
Send a private message to au7edd
Does anybody have a reasonable track chain laying about in the shed/paddock for a D8H46A near Bollon, Qld?
Thu, Jan 5, 2017 2:55 AM
Andrew
There is a bloke a St George that had a bit of 46A stuff. I will think of his name later.
Thu, Jan 5, 2017 6:44 AM
au7edd
Reply to Andrew:
Not scot bowman? Going into St George today.
Fri, Jan 6, 2017 5:05 AM
Andrew
Reply to au7edd:
Yeah thats c
The correct name.
Fri, Jan 6, 2017 6:57 AM
Mike Meyer
Thank you received: 6
Reply to Andrew:
Yeah thats c
The correct name.
I just saw a advert down here in Mexico from a bloke at Ballarat advertising wrecking a D8H, he says "all parts available" so might be worth a try zero four two seven zero five one nine nine six, I do not know him.
Good luck
Mike
Fri, Jan 6, 2017 7:43 AM
djcat
Send a private message to djcat
Reply to Mike Meyer:
Good luck
Mike
Are you chasing a "patch up" or something more permanent. I could lay my hands on some links that would new pins and bushes ( dry) pressed into them or some rather worn old chains without plates off a D8K.
Cheers djcat.
Fri, Jan 6, 2017 1:52 PM
au7edd
Reply to djcat:
Cheers djcat.
[quote="djcat"]Are you chasing a "patch up" or something more permanent. I could lay my hands on some links that would new pins and bushes ( dry) pressed into them or some rather worn old chains without plates off a D8K.
Cheers djcat.[/quote]
A patch up job would get us going again. Two links are completely US. The bush has fallen out. Where about are you & how much a link? Or PM me. cheers.
Fri, Jan 6, 2017 5:08 PM
au7edd
Reply to Andrew:
Yeah thats c
The correct name.
[quote="Andrew"]Yeah thats c
The correct name.[/quote]
Saw scot today. Sadly he has nothing.
Fri, Jan 6, 2017 5:09 PM
Mike Meyer
Reply to au7edd:
What about Paul Moore, have you tried him, or Deaf Jeff
Sat, Jan 7, 2017 3:39 AM
au7edd
I think both have been contacted.
Sat, Jan 7, 2017 6:15 AM
