Wanted, D2/D4 Pony Pinion Plate.
Showing 1 to 10 of 13 results
invisabledog
Send a private message to invisabledog
In need of a pinion plate for my 212 grader pony motor. Cat part number is 2A3623. Cat has them new, but I can't afford the price right now, hours cut at work. If anyone has a good used one, let me know. I was just going to rotate mine to a good spot, but it has cracks all the way around.
[attachment=22229]IMG_20140318_093649.jpg[/attachment]
Tue, Mar 18, 2014 8:55 PM
d9gdon
Here's a pile of used and aftermarket ones:
http://www.machinerytrader.com/list/partssearch.aspx?partnum=2A3623
Wed, Mar 19, 2014 12:31 AM
invisabledog
Reply to d9gdon:
Thanks Don. I'm hoping to locate one substantially cheaper than the $135 average most of those places are asking.
[quote="d9gdon"]Here's a pile of used and aftermarket ones:
http://www.machinerytrader.com/list/partssearch.aspx?partnum=2A3623[/quote]
Wed, Mar 19, 2014 2:14 AM
Thank you received: 77
Reply to invisabledog:
I think your best bet might be to visit the local boneyard unless someone like Hector has one on the shelf.
Wed, Mar 19, 2014 6:30 AM
Same part # on the 4G.
Wed, Mar 19, 2014 7:04 AM
invisabledog
That is correct, it is the plate the adjusting ring engages. Thanks GP
[quote="Garlic Pete"]I may have one in a 4G D4. I don't have a parts book for this carcass, though, so I don't now for sure whether that would be the same part as your 212.
If memory serves correctly, this the plate that the pony clutch adjusting ring engages, is that right?
Maybe someone on here could look up that part number for a 4G D4. I'll be out by it again tomorrow night and will see if that part is still on the tractor. If it is, and it is the right part number, I'll cover you for it.
Pete[/quote]
Wed, Mar 19, 2014 7:08 AM
invisabledog
Thanks OM, for verifying the part number.
Wed, Mar 19, 2014 7:09 AM
1948catD4
Send a private message to 1948catD4
heres some pics of my plate
Thu, Mar 20, 2014 7:44 AM
invisabledog
I definitely want it if serviceable. Is that on a grader? I'm looking for a few other small things for mine.
Thu, Mar 20, 2014 9:14 PM
gemdozer
Thank you received: 25
I have some pinion plates and more
Fri, Mar 21, 2014 2:22 AM
invisabledog
Many Thanks Pete. PM sent.
Mon, Mar 24, 2014 10:41 PM
