Wanted 4B0818 seal washer for pony motor
bvandragt
Send a private message to bvandragt
I need a seal washer #4B0818 that the output end of the pony motor crankshaft oil seal rides on. Cat wants $111 for one. Does anybody have a NOS or good used one?
Brian
Thu, May 29, 2014 11:50 PM
Cysco
bvandragt,
Try one of these sources as they each appear to have several in stock. They might have a better price.
Northwest Tractor Parts , Oregon
Phone: (503)658-5545
GREGORY POOLE EQUIPMENT , N.C.
Phone: (252)948-3111
or (800)932-7278
Have a good day.......Bill
Thu, May 29, 2014 11:57 PM
bvandragt
Reply to Cysco:
bvandragt,
or (800)932-7278
I already tried Northwest Tractor Parts, the 3 that they show on the web were actually used and when they looked at them they decided they were in too bad of condition to sell.
I will try Poole.
Brian
Fri, May 30, 2014 12:11 AM
Reply to bvandragt:
I will try Poole.
Brian
The one that someone else was looking for and decided to have it made?
It was a Thread in late 2013(winter)?
Fri, May 30, 2014 3:47 AM
bvandragt
Reply to drujinin:
I decided to buy one from Gregory Poole Equipment. It is NOS and was $80. You can't get much made at a machine shop for that. It still seems way too high for a mass produced stamping though.
Brian
Sat, May 31, 2014 3:01 AM
Thank you received: 77
Reply to bvandragt:
Brian
I think that's the problem Brian - they're no longer mass produced... Still, if you had a lathe, you could turn out a couple of dies and whip a hundred of them up : )
Sat, May 31, 2014 4:22 AM
Thank you received: 93
from memory I believe that in later days these washers were chromed on the seal lip run surface for rust prevention and longevity of service.
This would add markedly to the expense.
An option may be to get reasonable older ones machined and chromed.
Sat, May 31, 2014 6:00 AM
STEPHEN
Reply to edb:
I think that the OD is ground for finish and runout.
Sat, May 31, 2014 8:42 AM
bvandragt
Reply to edb:
Yes, that is part of the reason I needed a new one, the chrome is starting to flake off near the seal lip. Also the inside thrust surface that runs against the end of the main bearing is severely pitted.
Brian
Sat, May 31, 2014 8:44 AM
