Wanted, 3304 crank shaft or complete engine
old-iron-habit
Hi folks, I got a cracked crankshaft in the D4D I picked up with the knock in it. I am on the hunt for one. Thanks in advance.
Roger
Tue, Mar 31, 2020 6:49 AM
Check with Republic Diesel, Louisville Kentucky, been in business since 1911, excellent precision machine work, reman parts also. 502-561-2201
Tue, Mar 31, 2020 8:05 AM
D4C Charlie
Send a private message to D4C Charlie
Check out Machinery trader there are cranks on there. Is yours 330 or 3304? The crank in mine is pretty well worn to the limit but still goes and has some oil preasure. 78A D4 has the 330 and uses a 8M4505 crank there are other #s that fit also. Anyway good luck.
Thu, Apr 2, 2020 8:10 AM
SteveBudke
Send a private message to SteveBudke
Reply to D4C Charlie:
I have two candidates. Can you furnish forging numbers from bad crank.
Fri, Apr 3, 2020 2:15 AM
zmachine
Send a private message to zmachine
Reply to SteveBudke:
4N7694 with .030 Rods / .020 Mains Fresh grind 712-758-3720 located in Iowa
Tue, Apr 7, 2020 12:31 AM
old-iron-habit
Reply to zmachine:
Thanks. Calling you. EDIT Seems to be a fax number. Sent a PM with my number.
Tue, Apr 7, 2020 2:08 AM
