Track wrench
Track wrench
Showing 1 to 10 of 10 results
Aaron
Send a private message to Aaron
[attachment=54982]cat2.jpg[/attachment]
Track wrench 1B5773 2 3/4 " across the flats
$100.00 OBO
Sun, Aug 11, 2019 10:30 AM
Thank you received: 289
Is that one for a D4 Aaron? JM
Sun, Aug 11, 2019 9:14 PM
Aaron
Gee, it looks like from a discussion years ago on here that it fits then RD6 from 2H1 to 2H3247 after that on that series was no longer used, also in that discussion someone said that the D4 was 2 3/4 also, none of which I know personally, a friend of mine had it in a shed her dad had a bunch of stuff in that was the only Cat part we found
Part of the discussion:
1B5773 wrench was used in some Cat tool kits until mid 1937 going by the serial number breakdowns. So it makes sense that it would've been used on the Forty, Diesel Forty, and RD6 as they were basically the same machine. Possibly even on the Thirty Five and Diesel Thirty Five too, but I don't have the books on those models to verify for sure.
Sun, Aug 11, 2019 9:36 PM
Reply to Aaron:
I’ll measure one of my D4s adjusters. I can’t remember if 2 3/4” or 2 7/8”. If it’s for a D4, I’d like it please.
Thanks.
Sun, Aug 11, 2019 11:32 PM
nomorejohndeere
Send a private message to nomorejohndeere
Thanks.
I like the bend
gettin in the groove
Mon, Aug 12, 2019 6:45 AM
Reply to nomorejohndeere:
I like the bend
that bend is much more severe than my D4 track wrench
Mon, Aug 12, 2019 7:49 AM
Aaron
Reply to dpendzic:
Gee, you going to Brooks the end of the month.
Mon, Aug 12, 2019 9:48 AM
Reply to Aaron:
D4 track adjuster wrench is 2-3/4" but neither the straight jaw or angle jaw versions have that bend in the handle.
Mon, Aug 12, 2019 12:41 PM
josh
Thank you received: 14
1B5773, AKA 9F3869, 4A0045, 3B3874, 1A6038.
This scan from an early RD6 Parts Catalog.
Mon, Aug 12, 2019 1:20 PM
Reply to Aaron:
Nope. PM your mailing address, so I may send you a check. You can hand the wrench to Dennis or ShaNayNay, and I can get it from one of them later.
***I have a straight version of the track wrench, the bent or offset is better I think. I modified a water pump wrench for a D8 2U ( I know, wrong tool) to spin those adjuster nuts when they are loose***
Thank you Aaron. JM
Mon, Aug 12, 2019 11:31 PM
Aaron
Thank you Aaron. JM
Thanks Gee, wlll do.
I can call you on my way thru nest Thur if your close to 5,if not I'll give it to Dennis.
Tue, Aug 13, 2019 9:11 PM
