Thirty-Five exhaust valves for a gas engine
Old Cats
Send a private message to Old Cats
I am looking for the part number for the exhaust valves on a Thirty-five we are working on. Or if anybody has some valves that will clean up they are 6 7/8 overall length, 2.2 head diameter and .495 stem (I would guess .500 would work since a seat pilot that size fits well. Thanks in Advance Old Cats
Sat, Oct 3, 2020 12:30 AM
josh
Thank you received: 14
The exhaust valves on the Thirty Five, 5C1-5C1728 are S-1609, same valve used on the S and PS Thirty tractors.
Sat, Oct 3, 2020 12:53 PM
Old Cats
Reply to josh:
Thanks Josh, That makes the search much easier.
Sat, Oct 3, 2020 7:28 PM
Mike Meyer
Thank you received: 6
Can exhaust valves be used as inlet valves too, though I assume inlet valves should not be used as exhaust valves?
"Stephen" on here made some nice valves for his 30 recently using D8 valves, check his threads for the story.
Mike
Sun, Oct 4, 2020 4:10 AM
Old Cats
How do I get to the private message? Or is it coming to my email? I am not too hot on this computer stuff and with the new website I haven't been able to find my way around too well.
Sun, Oct 4, 2020 10:35 AM
Old Cats
OK I found the private message and will give you a call, if you want wait to send the front crank assembly and it can all come together.
Gene
Sun, Oct 4, 2020 10:42 AM
