Tailseat D4 7U
Tailseat D4 7U
Showing 1 to 10 of 20 results
CrawlerAddict
Thank you received: 13
Got this back in February from a trade with JM and was intending to make her fully operational again but plans have changed and it needs more work than I have time for. Was told main engine runs and it drives and steers but haven't touched it since I brought it home. Someone has torn into the the pony and don't know the reason but the heads are off it, the magneto is missing and the carburetor was broken in pieces so I assume its in bad shape. The track chain bushings on one side are completely worn through. The rest of the machine is in good shape, the bushings on the other side have wear but nothing like the other side because the track tension was adjusted properly with the correct amount of slack. Someone ran it with the other side cranked out super tight which just ate the bushings. I will add more detailed pictures of it tomorrow. Located in Northern California asking $1000.. I have a complete 7J machine that was planned to be used for the needed tailseat parts but haven't touched it since bringing it home as well. Main is locked up on it but pony spins free and is complete. The undercarriage is in good shape with some wear on bushings but lots of life on them and have never been turned. Asking $500 for it.
Make me an offer, just need them gone!
Sat, Oct 4, 2025 4:11 AM
CrawlerAddict
Sat, Oct 4, 2025 4:15 AM
CrawlerAddict
CrawlerAddict
Sat, Oct 4, 2025 4:16 AM
CrawlerAddict
CrawlerAddict
Sat, Oct 4, 2025 4:17 AM
CrawlerAddict
Here's more pics of the tailseat. Have all the parts that have been removed.
Sat, Oct 4, 2025 3:42 PM
CrawlerAddict
CrawlerAddict
CrawlerAddict
Sat, Oct 4, 2025 3:43 PM
CrawlerAddict
