Starter motor wanted
Showing 1 to 10 of 12 results
Bentzdo
Send a private message to Bentzdo
I need a starter for a D-2 direct start 5U serial number 15599
Doug
Mon, Mar 4, 2019 10:59 AM
old-iron-habit
Your 5U did not come with a factory direct starter. Check the sticky at the top of the first forum page for tons of information on direct start conversions. I'm sure the starter you need will be listed there.
Tue, Mar 12, 2019 8:26 AM
Thank you received: 64
Reply to old-iron-habit:
That's not correct, direct electric start became available at s/n 5U14695. Uses the early 40MT with inertia drive.
Unique to the D2 and if you go to the later conversion type starter you need to slightly offset grind the flywheel housing hole due to the conversion drive gear diameter being slightly larger.
Wed, Mar 13, 2019 6:33 AM
old-iron-habit
[quote="Old Magnet"]That's not correct, direct electric start became available at s/n 5U14695. Uses the early 40MT with inertia drive.
Unique to the D2 and if you go to the later conversion type starter you need to slightly offset grind the flywheel housing hole due to the conversion drive gear diameter being slightly larger.[/quote]
I did not know that OM. It was available the last 4 years then. It probably was not sold often with that option here in the north country. Did it have glow plugs also? Thanks for setting me straight.
Tue, Mar 19, 2019 8:56 AM
Bentzdo
My information indicates 5U 15599 is a 1955 model.
Fri, Mar 22, 2019 10:55 AM
Yes, glow plugs are included with the option.
Fri, Mar 22, 2019 12:25 PM
Thank you received: 288
Old Magnet Sir: would 5U16971 already have a hole bored in it for an electric starter? My latest D2 has a rope start pony. I’d like to have the best of both worlds with DE and pony if it would work. Thanks! JM
Sat, Mar 23, 2019 4:17 AM
STEPHEN
Believe it should. Look for a cover plate under the pinion control. To use an original hole you will need an original starter or alter the hole to fit a later starter.
Sat, Mar 23, 2019 10:23 AM
Reply to STEPHEN:
Direct electric start came in at at s/n 5U 14,695.
Sat, Mar 23, 2019 11:39 PM
OM---any idea on the 4U series? I do have the plate and hole on the housing so does that mean an original 40mt starter would fit right in?
Sun, Mar 24, 2019 1:39 AM
STEPHEN
Reply to dpendzic:
Yes, unless it has been altered
Sun, Mar 24, 2019 2:09 AM
