Sixty oil pressure gauge
Showing 1 to 6 of 6 results
biggastractor
Looking for an oil pressure gauge for my CAT 60. Parts book says its a 2814A. Would like to get a brass CAT gauge. Repairable is OK. if I can't find one, does someone know of a suitable replacement? I had some modern "after-market" one that was showing low oil pressure. I replaced it with a borrowed CAT original guage and that showed I had great pressure.
Biggastractor
Mon, Jul 9, 2018 9:49 AM
cojhl2
Unless you are certain that one gauge is correct an the other incorrect, I would test with a third gauge.
Mon, Jul 9, 2018 10:07 AM
biggastractor
Reply to cojhl2:
cojhl2,
That CAT gauge was a tested gauge, know to be good. thanks for the reply.
Biggastractor
Mon, Jul 9, 2018 10:21 AM
josh
Thank you received: 14
Reply to biggastractor:
cojhl2,
Biggastractor
If you can't find original, 2814A, 2-13/16" gauge, is updated to 2H3129 or 4B2796, 2-3/16" gauge, and 4B8392 or 4B6214 bracket and 2 9F9327 screws.
Mon, Jul 9, 2018 1:10 PM
biggastractor
Reply to josh:
Josh, Thanks for the info.
Biggastractor
Mon, Jul 9, 2018 8:57 PM
doylex
Send a private message to doylex
Biggastractor
had a few done here http://www.gaugeguys.com/
Thu, Jul 12, 2018 6:40 PM
biggastractor
Reply to doylex:
Guys ,
Thanks for all the help. Still looking for a correct gauge but will buy a 5M1065 from Zeigler tomorrow. They have one in stock that will substitute and cross-references to the 4B2796 and the 2H3129. It is obviously not the correct one but I need a working oil pressure gauge and that will have to do until I can find the correct old one. New one is 1/8 pipe thread nipple centered on the back of the gauge, 2 3/16 wide with a green- red-white face
Thanks again
Biggastractor
Wed, Jul 18, 2018 6:48 AM
