Selling: D47U25103 Orchard unit
Showing 1 to 10 of 14 results
Thank you received: 279
[img]/media/kunena/emoticons/playball.gif[/img] No room at the inn!
As mentioned in other threads, I have TOO MANY D4s here! Time for someone else to enjoy owning one…
7U 25,103 electric pony equipped; live front BeGe hydraulic unit. 41 pump guard, partial belly pan/hook will be removed prior to sale.
Machine starts east, steers and brakes nicely. Grousers are purposely worn for walnut/almond orchard floors; bushings have been turned and noticeably worn, but plenty of life left. Decent rail height and lifetime rollers.
FOB Yuba City, CA (North of Sacramento International Airport 35 minutes). $4750.00 USD, 10% Discount for ACMOC members! I’ll probably donate some of the proceeds to the scholarship fund and some for chapter 15 activities. Thanks for looking. Juiceman.
(530) Four one five-0504 text is okay, or [email protected]
Mon, Feb 24, 2025 10:17 AM
side-seat
Thank you received: 16
WOW those fenders look very heavy! They appear to be 1/2" plate?
Mon, Feb 24, 2025 6:52 PM
Reply to side-seat:
[quote="side-seat post=261765 userid=956"]WOW those fenders look very heavy! They appear to be 1/2" plate?
***There is a "lip" or "hem" welded along the edges making it look thick. Without measuring, I want to guess 1/4" or 5/16" material. I think they will unbolt in 2 sections*** Still much heavier than the stock "tin" fenders offered from the factory. I think I have a semi rough set of originals and some other goodies to toss in if anyone is interested. I was impressed with the ride when I took it out for a few laps yesterday. Very smooth compared to a D2 orchard machine. JM
 [/quote]
Mon, Feb 24, 2025 11:27 PM
Thank you received: 187
Check Busters - go with it? Some of those are tough to find today. How can you compare a bucking bronco (D2 tailseat) to a well broke quarter horse (7U D4)? Quite the statement from JM who just loves those D2's!
Wed, Mar 12, 2025 3:33 AM
The check breakers remain on it. In all my years of buying "stuff", I have only encountered one set ever for sale at an auction, and shocked to see them sell for over $800.00 by themselves! I might have to bring Professor Fugly to Tulare with my tandem Goble ridger and show folks how irrigation checks are put up. I know CTS wants this unit, but the pony starts too easily for a guy like him...JM
Wed, Mar 12, 2025 2:43 PM
clayton
Thank you received: 25
I’ve seen check breakers before what are they used for and is “check breakers” the correct terminology?
Thu, Mar 13, 2025 12:43 AM
The ones pictured are flipped in the "up" position, when turned over to the lowered position, they push dirt out of the path of the track pads, for a smoother ride, say over a freshly made irrigation ridge. No climbing over a ridge or irrigation "check" that is 2' high, you can drive thru it, rather than over it. A must have for someone that uses an orchard machine for putting up irrigation ridges/checks/dikes. Even when cross disking an orchard, sometimes the disk isn't adjusted properly to keep the front gang from throwing a mound of dirt towards the tree head/berm, so its the same; the check breakers push the loose soil away and you don't get thrown off the machine climbing a hump. JM
Fri, Mar 14, 2025 6:04 PM
clayton
Thank you Juiceman for the explanation I can totally visualize how they work, there’s a D2 not far from me that has them on it. I’m really slobbering over trying to acquire it! That would make no. 7 D2’s if I could equire it!
Fri, Mar 14, 2025 6:24 PM
You had better make it "Lucky number 7" before someone else snags it! I have 5U 16,971 here as an orchard machine equipped with check breakers and live hydraulics, not to mention dual starting set up; pony and direct electric. Its a fun one to own and operate. JM
Sat, Mar 15, 2025 9:06 PM
clayton
So looking at the pictures I took I wonder if the check breakers on this D2 are cat oem or aftermarket?
Sat, Mar 15, 2025 10:08 PM
clayton
Sat, Mar 15, 2025 10:09 PM
