saw this, someone should get it
Showing 1 to 9 of 9 results
veerCAT
Send a private message to veerCAT
Thank you received: 5
early 15. not mine, just sharing the ad I saw
https://sfbay.craigslist.org/sby/grd/6815759518.html
Tue, Feb 12, 2019 11:33 PM
ag-mike
unlucky 13 👍
Wed, Feb 13, 2019 4:34 AM
Andrew
Reply to ag-mike:
unlucky 13 👍
Is that really the correct serial no. stamped on the radiator surround ???
Wed, Feb 13, 2019 7:56 AM
naylorbros
Thank you received: 31
Reply to Andrew:
Just looking at the pictures. PV13 has the wrong drawbar brackets/drawbar (Twenty Two style) on it but the parts tractor has a correct set. The plates that sandwich the drawbar on the parts tractor look home made. I was going to say that the front fuel tank brackets were incorrect for that early a tractor but I was looking at pictures of the parts tractor.
Ken
Wed, Feb 13, 2019 10:00 PM
Lance Jones
Reply to naylorbros:
Ken
The drawbar fitted on Sale Unit was on Machines s/n PV 7425 Up .be interesting to see s/n that is stamped Beside Gearshift ,Could have had Change Motor Fitted or Upgraded Drawbar set up [Which is same as a 22 LJ
Thu, Feb 14, 2019 12:08 AM
Thank you received: 93
Reply to Lance Jones:
it is possible that V13 is the Part Number for the side panel of the radiator.
There are many low P/number V prefix parts on theses small machines.
Thu, Feb 14, 2019 9:37 AM
ag-mike
Reply to edb:
wouldn't the s/n be stamped at engine flange to oil pan?
Thu, Feb 14, 2019 9:42 AM
G.Costanza
Send a private message to G.Costanza
Reply to ag-mike:
If you enlarge the picture, you can see PV 13. The 10s also had the serial # stamped in that area also
Thu, Feb 14, 2019 10:50 AM
brewzer
Reply to G.Costanza:
It was typical of the very early 10s and 15s to have the number stamped on the radiator side panel.
Wally
Thu, Feb 14, 2019 12:24 PM
Reply to brewzer:
Wally
indeed, the picture when magnified greatly shows the P is just visible--reason I usually rub school board chalk over such numbers to better highlight them especially for photographic purposes.
Seems odd to put the S/No on a vulnerable piece like that.
Thanks.
Fri, Feb 15, 2019 4:47 AM
