Reproduction water pipes
Showing 1 to 7 of 7 results
WyoCat
I have some reproduction pipes for the 10/7C&1D15, 15/8C20 and RD7 tractors. They are made with a little extra length on each end so that you can cut down and fit to your tractor using your original flanges. If you need flanges, I can do those for you as well. Radius' are a perfect match to originals. All pipes made from .120 wall material.
T222. $36
V84. $44
3B1174. $120
All prices plus shipping.
Have a pipe that you need made? Just let me know.
Chad Enyeart
Wed, Feb 22, 2017 9:31 AM
Texasbest
Send a private message to Texasbest
Are you going to do any for Twenty Two's ?
Roby Whitehead
Thu, Feb 23, 2017 9:12 AM
michael J. matsago
Send a private message to michael J. matsago
Reply to Texasbest:
Roby Whitehead
Morning Chad just thought I'd touch base with you. How;s the weather treating you an
d your family? Please let me know when you are ready to ship my order Take Care. Michael J. Matsago 570 778 1655
Thu, Feb 23, 2017 9:52 PM
WyoCat
Reply to michael J. matsago:
Hey Texasbest! I can do the 22's, no problem. I will put that in on my next run.
Hey Michael! We had a short period of warm weather, but February sure quickly reminded us again of the fact that May is a long ways away. 6 degrees this morning and snow on the ground. I will reach out to you later this weekend.
Chad Enyeart
Sat, Feb 25, 2017 10:46 PM
Thank you received: 77
Reply to WyoCat:
Hey Chad, if you can make up the tube for my D2 pony's exhaust that'd be great. It's serial 5U13753 so it has the wide radius bend from the right side port over to the left side casting. Just regular mild tube but I know the local exhaust shop does not have that radius die. I can mig it on to the flanges.
Tue, Feb 28, 2017 7:21 PM
If you do the "U" model D2/D4 pony exhaust pipe how about doing it in stainless steel.
Thu, Mar 2, 2017 12:33 AM
I figured if Chad could pull this off, I'd want it to be easy on him. Stainless is a (bit) harder to work but not especially so. It would definitely be my preference OM.
Thu, Mar 2, 2017 2:03 AM
WyoCat
Getting the radius' correct is the tough part. Let me see what can be done.
Chad Enyeart
Thu, Mar 2, 2017 3:56 AM
