RD4 LeTourneau PCU
RD4 LeTourneau PCU
Showing 1 to 6 of 6 results
ironman3406
Chapter Twenty Seven
Send a private message to ironman3406
Hello I am in search of the double stacked shiv assembly for the PCU on my RD4.  I recently acquired a model D carryall so would like to get the pair all set up. Pictures for reference.
thanks
Nathan
Sun, Nov 13, 2022 12:30 PM
caterpillar13
try GENERAL GEAR in idaho
Mon, Nov 14, 2022 12:20 PM
AkinRanch
Send a private message to AkinRanch
Reply to caterpillar13:
I’ll check my LeTourneau boneyard. I have a several control units. I’ll have to educate myself and see if I have what you need. My 5T D4 has the same LaTourneau D behind it now, so I’m familiar. I’m out flying until Thursday, so I’ll check the boneyard then and get back to you.
Tue, Nov 15, 2022 1:38 AM
ironman3406
Reply to AkinRanch:
Thanks so much Akinranch look forward to learning what you might have!
Thu, Nov 17, 2022 11:23 AM
AkinRanch
Reply to ironman3406:
Looks like I have about anything one might need to get an operable LeTourneau unit going. I have seven or eight mostly complete units.  The green one is on my 5T D4 and operates quite nicely.  Four are still mated to their parent tractor.  I’m not well versed in the various LeTourneau PCU models, but they seem to be similar in size.  And the shive blocks all appear similar in size.  Various units are mounted on:  D8 1H, D7, D6 4R, D6 5R, and at least five others outdoors on the ground or on pallets.
I’m located in California.  If you can’t find anything in Canada, I could help.
Sat, Nov 19, 2022 11:04 AM
Thank you received: 288
I wonder if the sheave unit from my 3T D7 would work.
I am northwest of Akin about 1.5 hours. JM
Mon, Nov 28, 2022 12:51 AM
ironman3406
As far as I have been able to learn the sheave assembly is the same on them all, so I’m certain it would. Are you at all interested in breaking the unit apart tho? Thanks
Nate
Tue, Dec 13, 2022 12:00 AM
