PTO assembly for CAT D2
Showing 1 to 7 of 7 results
crookedwrench
Send a private message to crookedwrench
No History. Unit came with 2019 purchase of the tractor. Have added Hyster 2N winch and have no need for the PTO. 270 993 1191
Fri, Apr 24, 2020 2:41 AM
Is it my eyes or is that shaft twisted?????
Fri, Apr 24, 2020 4:01 AM
crookedwrench
Yes. Your eyes are not wrong. There is a twist on the shaft.
Fri, Apr 24, 2020 6:22 AM
Steve A
Reply to crookedwrench:
That must be the strongest running D2 ever !
Fri, Apr 24, 2020 8:19 AM
chuckb
Reply to Steve A:
the mighty d2 took another hit just looks like a little bend in the shaft
Fri, Apr 24, 2020 11:41 PM
Hobo groh
Send a private message to Hobo groh
Reply to chuckb:
How could a d2 do that I’ve never even seen a bent shaft on a tractor
Sat, Apr 25, 2020 4:20 AM
ag-mike
Reply to Hobo groh:
jack-knifed with connected pto implement, in reverse. Maybe going forward???? I believe when you use a add on pto gearbox you need to extend the drawbar. Something about SAE specs.
Sat, Apr 25, 2020 5:52 AM
Reply to ag-mike:
Not uncommon to see that when running a rotary mower without an over run clutch. A lot of inertia there.
Sat, Apr 25, 2020 11:35 AM
