Precombustion chambers
Showing 1 to 7 of 7 results
Catboy1
Send a private message to Catboy1
Could someone please tell me what models these precombustion chambers fit? I can’t find part numbers on them and I have a few of each I’d like to sell. Thank you guys for all your help,
Robyn
1 [attachment=64484]0F50FE60-CEE9-46E4-B693-64BEC5531E9F.jpeg[/attachment]   1[attachment=64485]9BE95C71-3E21-468E-81BD-52BD4D368C8C.jpeg[/attachment] 2[attachment=64486]DFD96F28-0295-48D2-A084-817E2D65073C.jpeg[/attachment] 2[attachment=64483]2D3D3BCD-C3B8-4867-8387-71B853555EB4.jpeg[/attachment] 3[attachment=64487]6418A4A9-6BCB-48AE-BFC7-7538F7FEA322.jpeg[/attachment] 3[attachment=64488]725E7848-AB44-40E4-8D24-38CDB6A63B46.jpeg[/attachment]
Sat, Sep 4, 2021 1:07 AM
Supply thread diameter and tpi...that may help identify.
Mon, Sep 6, 2021 2:23 AM
tpi is threads per inch Robyn.
Mon, Sep 6, 2021 3:54 AM
Catboy1
Okay, here are the measurements:
1- diameter .981, tpi 12
2- diameter 1.112, tpi 12
3- diameter 1.215, tpi 12
Tue, Sep 7, 2021 12:45 AM
Reply to Catboy1:
Best guess is the O.981 (1" nominal) is for early D2
The 1.112 (1-1/8" nominal) is for early D4, D6.
The 1.215 (1-1/4" nominal) I'm not sure of application but if a 1-1/2' hex head fits it's for the early 5-3/4 or 5-1/4  bore engines.
Tue, Sep 7, 2021 11:31 AM
Catboy1
thank you, Old Magnate.
Tue, Sep 7, 2021 12:01 PM
Catboy1
Reply to Catboy1:
Magnet, darn auto correct.
Tue, Sep 7, 2021 12:02 PM
Thank you received: 93
Hi Robyn,
I do have the scans below but that is all at present.
Orifice sizes are critical to application and the scan of the D311, D315 and D318 diameters given are likely to be for the body size--I am unsure what they are actually referring to be honest but thought they may assist you in your quest.
Good Luck.
Tue, Sep 7, 2021 12:16 PM
