Oversize Pistons Wanted D2/D4 and D6 Pony Motors
Showing 1 to 7 of 7 results
Oldcarman
Send a private message to Oldcarman
Anyone have any good used (or New) pony pistons that you could part with? I'm working on small and large opposed pony motors. I've checked around the normal sources (Florin etc) and haven't scared any up. My engines have some pretty deep bore pits and I doubt that the will clean up at .020, so would prefer larger but will consider whatever you've got. Sleeving back to standard is an option, but the sleeves are more expensive than I thought.
Interested in any oversizes you might have available.
D2/D4 Part number 3B5172
D6 Part Numbers 2F3668, 8H2761, 8H2760
New member of ACMOC in 2019
Please email to [email protected]
Thanks!!
Greg
Sun, Jun 9, 2019 9:16 PM
gemdozer
Thank you received: 25
Sorry have 6 pistons for d4 standar 2f3665
Sorry have 10 pistons for d6 stndar 2f3669
Mon, Jun 10, 2019 3:08 AM
wtparts
Send a private message to wtparts
Reply to gemdozer:
Greg
I sent a private message. call me 816 229 3411 or cell 816 223 3130
Roland White White Tractor Parts Blue Springs, Missouri
Mon, Jun 10, 2019 11:12 PM
Walter
Send a private message to Walter
Reply to wtparts:
Greg
jp pistons in australia. had any size i needed. not had any problems with service or pistons
Tue, Jun 11, 2019 7:43 AM
Thank you received: 78
Reply to Walter:
Pretty sure I bought pistons for my pony from JP - good service alright.
Thu, Jun 13, 2019 11:15 PM
bboaz
I have 4 D-6 Pony Pistons. 2 used and 2 new.
2 each 2F3669 used. Appear to be standard size pistons. One measures 3.1015 at the lands and 3.1180 at the skirt. The other one measures 3.1000 at the lands and 3.1180 at the skirt. I have no idea what standard pistons are suppose to measure but one seems to be .0015 larger than the other at the lands and skirts being the same.
1 each Semi-finished piston 2F 3668. It Measures 3.1930 at the lands and 3.1935 at the skirt. To be turned down up to ,060 oversized
1 each What looks like a semi-finished piston with no numbers. It measures 3.1320 at the lands and 3.1460 at the skirt. Seems to be .030 oversized.
You are welcome to any or all of these pistons since they have been setting in a cabinet for what seems like forever and I have no use for them. All I would ask is to be reimbursed shipping if they will work for you. Text or call and leave a message (I get robo calls and most time don’t answer if I don’t recognize the number)and or an address at 573 433 nine two seven seven if you are interested. Brian Boaz
[attachment=54422]20190622_194110.jpg[/attachment]
Sun, Jun 23, 2019 10:39 AM
Oldcarman
Reply to bboaz:
Brian,
Thanks much. I'll get them into engines and put them to work again!! I left a voice mail and sent a text with info.
Greg
Mon, Jun 24, 2019 12:01 AM
Thank you received: 95
Reply to Oldcarman:
Brian,
Greg
from memory the JP semi finished pistons may nearly get out to 0.080" o/s.--I stand to be corrected.
Scan is of pony piston sizes for the relevant O/Sizes for both Horizontal and Vertical engines.
Mon, Jun 24, 2019 9:55 AM
