Old Cat Throttle Quadrant Parts needed:
Showing 1 to 10 of 11 results
Russelln
Send a private message to Russelln
Looking a For PAWL (2B5394) and Spring (L-955) which is now crossed over to a (0L0955)
These 2 parts fit inside the (5B2726) Lever Assembly.
These are needed on my CAT 12 Motor Grader 8T Model, However I hear these parts were also used and very common to many of the earlier Dozers.
Cat 12 Grader 8T6375
Cat D8 2U12593
Mon, Jul 22, 2013 4:47 AM
farmallzach
Send a private message to farmallzach
If this is the same part used on a 7T grader I may have what you are looking for, I know early 8T's used the same quadrant as the 7T's or at least I think they did.
Mon, Jul 22, 2013 5:24 AM
Dozerman51
Reply to farmallzach:
Hi Russelln,
Florin Tractor in Sacramento has the 5B2726 lever assembly. Listing is current as of 07-16-13. Their PH# is (916)383-0317. FP Smith in Fairfield lists the 0L0955 spring. Listing is current as of 07-20-13. PH# is (88😎610-6919 or (707)864-1122. Talk to Liz Olson. She is a great person to deal with. You never know, Peterson Cat or Holt of Calif. might still be able to get you the parts; although you would be paying more $ for them. Hope this Info helps. 👋
Joe Giraud
1940 Cat D2/3J (Seat Tank model)
1941 Dodge WC-12 Military 4x4 1/2 ton pick-up
Mon, Jul 22, 2013 5:51 AM
Russelln
Reply to Dozerman51:
Hi Russelln,
Joe Giraud
[quote="Dozerman51"]Hi Russelln,
Joe Giraud
1941 Dodge WC-12 Military 4x4 1/2 ton pick-up[/quote]
Thanks Dozerman, I have talked to Fairfield and Dennis Carroll at Florin, Both have it listed, but none in stock with no lead time. I currently have the 5B2726 Lever assembly on the Grader along with the ratchet, I inners to the 5B2726 are missing and have been since I inherited this machine. I need them to keep the throttle from floating while grading, mainly to keep it full open.
Cat D8 2U12593
Mon, Jul 22, 2013 7:58 AM
Russelln
That would be awesome, If only we had a way of making sure they were the same part. My parts book only covers 8T1 to 8T14782
Cat D8 2U12593
Mon, Jul 22, 2013 7:59 AM
farmallzach
Reply to Russelln:
I have a complete quadrant. The parts are the same according to my parts book. I will look tomorrow and see if I can get it apart and see if I can salvage the parts.
Mon, Jul 22, 2013 9:01 AM
Russelln
Many thanks..
Cat D8 2U12593
Mon, Jul 22, 2013 9:28 AM
Russelln
Reply to Russelln:
Many thanks..
Bumping it up.
Cat D8 2U12593
Sat, Jul 27, 2013 7:37 AM
farmallzach
Reply to Russelln:
Bumping it up.
Will these fix you up. I sent you a private message a few days ago. PM me your address so I can send them to you. [attachment=18800]IMG_20130804_080938.jpg[/attachment][attachment=18801]IMG_20130804_080928.jpg[/attachment]
Sun, Aug 4, 2013 8:21 PM
Russelln
OMG, That is exactly what I need, I sent you a PM. I never seen one from you though.
Cat D8 2U12593
Sun, Aug 4, 2013 8:56 PM
Russelln
I got this message when send you a PM:
farmallzach has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Cat D8 2U12593
Sun, Aug 4, 2013 10:35 PM
