Need D318 wet clutch engine complete
Ace Flyguy
Send a private message to Ace Flyguy
As Murphy strikes again. We just lost a member of the family , our dear D318 lost a rod. Found the pieces but engine is done. Went threw both sides of the block and the oil pan.
So I need a running or not complete D318 something I can rebuild or good complete bottom end and block with wet clutch oil pan.
This is off a cat 12- 70D3223 "59" model.
And or if anyone knows if another later engine will retro in I am willing to do that.
I'm in Kenai Alaska. Will ship anywhere in us. Just need a motor.
Thanks guys.
BTW, this had pony motor. With machined spot for starter so can use lots of parts off mine still. Head is also excellent shape.
John Perry
907-394-3579
Sun, May 17, 2020 2:55 AM
Thank you received: 52
Not just any D318 will do. Has to be compatible with grader oil clutch configuration. Different block, crankshaft, flywheel and oil pump to deliver and return engine oil to clutch.
Sun, May 17, 2020 6:23 AM
Mschwartz
Hello is a 318 from a D6 9u farm tractor going to be compatible? Have two parts tractors with oil clutches, both turn over but are missing parts to start and I have not tried to run them. Located in eastern Washington, Mike
Mon, May 18, 2020 3:23 AM
Thank you received: 37
Reply to Mschwartz:
Hi Mike,
as OM and others have said above, ONLY a Grader engine will fit as there are many differences for the oil clutch system for the Grader engine application--different and special crankshaft and cylinder block for starters--these are major items that are NOT used in any other applications and so a D6 or other application D318 CANNOT be used in your Grader as a replacement.
You are limited to finding a used Grader application engine only and/or parts.
Mon, May 18, 2020 9:44 AM
Fat Dan
Reply to edb:
Hi Mike,
I see some older Cat graders down in Nikiski (look in Anchorage CL) all the time on Craigslist. I'll Keep an eye out... think there is a Cat 12 for $4500 in Nikiski right now
Good luck
OOps Big Lake and it's a 12F ... texted him 'JUST SOLD' was a 3306 anyway
https://anchorage.craigslist.org/hvo/d/wasilla-road-grader/7124972621.html?lang=en&cc=gb
Looking to trade road grader for backhoe. The grader is a Caterpillar 12F. It is an older machine and has had a lot of use. It runs great and all functions work.
Caterpillar 12 G Grader (Fairbanks)
https://fairbanks.craigslist.org/hvo/d/fairbanks-caterpillar-12-grader/7105119932.html?lang=en&cc=gb
1978 Caterpillar 12 G Grader
2095 Hrs ( thought to be original due to condition of machine)
Push Block
Multi Shank Ripper
Arrangement # 2G6012
Cutting Edge # 5D9558
Tires- 14 X 24 (2 New) others showing some weather checking
Just trying to help, and you are looking for a D318, 6Cyl. 50's -60' from No.12 and/or 12E? ... sorry can't see you listing right now
good luck
Tue, May 19, 2020 2:33 AM
Ace Flyguy
Reply to Fat Dan:
Good luck
Push Block
Multi Shank Ripper
good luck
Thank you to whoever saw this wanted poster. Then called the guy in California who's dad passed away. His dad had purchased a D318 wet clutch motor out of a grader in Texas I believe , hauled it to California, rebuilt the complete engine. I purchased it today and shipper has it. Will be delivered next Friday hopefully.
JP
Tue, May 19, 2020 12:22 PM
D6 Pete
Reply to Ace Flyguy:
JP
Hello ALL ,, could someone help me to get in touch with the guy in Alaska with the 12G ,, I cant reply thru Craig list from here in Aussie ,,,Have been looking to buy a Cat 12 G for some time ,,, would like to talk to the owner in Alaska ,, E mail is best for me [email protected] Thanks for any help ... Kind Regards pete....ps ... have shipped quiet a few old Cats from CA ,, few years back ,,,, sure would love to visit Alaska to run that one there !!! .. Take Care ALL ....
Tue, May 19, 2020 1:35 PM
Fat Dan
Reply to D6 Pete:
Your PM in box is full
Poo the 12G is gone..
there is a Cat 140G new listing
Wed, May 20, 2020 7:06 AM
D6 Pete
Reply to Fat Dan:
Dan did you see how much $$ the 12G made ?? .. Regards pete
Wed, May 20, 2020 12:47 PM
