MAKE OFFER 7H1004 D339 Rebuilt Engine Block have 2
Showing 1 to 6 of 6 results
wtparts
Send a private message to wtparts
Make reasonable offer , blocks were rebuilt by a major rebuilder have two in stock,previously priced at $450.00
White Tractor Parts Blue Springs, Mo. 64015
Roland White 816 229 3411 or cell 816 223 3130
Wed, May 8, 2019 1:43 AM
stanerik
Send a private message to stanerik
Are these block still for sale? I have a 48A4101 160hp.
Mon, Mar 30, 2020 9:44 AM
wtparts
Reply to stanerik:
Thanks for the reply, yes I have 2 D339 rebuilt blocks , looking for a good offer your choice. Casting number 7H1004,check yours.
Where are you located?
White Tractor Parts 2301 W 40Hwy, Blue Springs, Missouri 64015 ,located 20 miles east of Kansas City, Missouri
e-mail [email protected]
816 229 3411 or cell 816 223 3130 or res. 816 229 8488
Roland White
Mon, Mar 30, 2020 11:32 PM
Thank you received: 64
Reply to wtparts:
Roland White
I show 7H1004 block casting to be for a late D339 Industrial Engine with either a 3.875" or 4.875" thrust width.
Also used on late 47,48A D7
Tue, Mar 31, 2020 1:28 AM
djcat
Send a private message to djcat
Hi all,
I have just rebuilt a 17A engine with the 7H1004 cast number. The block does not have the hole in the back for an accessory drive shaft like the D7E's which they require to run a hydraulic pump.
Cheers djcat
Fri, Apr 3, 2020 5:30 PM
Reply to djcat:
Hi all,
Cheers djcat
Are you sure that's not a 7H1004 block casting number and yes that is an Industrial Engine that wouldn't have the accessory drive. I can't come up with a 7H1007 number.
Sat, Apr 4, 2020 4:36 AM
djcat
Yes OM your right I had it right in the title but but hit the wrong button in the text.
Thanks for pointing that out.
Cheers djcat
Sun, Apr 5, 2020 4:23 AM
