Looking for part #
Looking for part #
Showing 1 to 10 of 10 results
zip
Send a private message to zip
Looking for a part # for a 39 9k grader master cylinder cap and gasket I believe 1 1/4 theads
Mon, Mar 30, 2020 12:54 AM
Cap/plug 4B8987
Gasket 4B8988
Mon, Mar 30, 2020 1:22 AM
zip
Cap/plug 4B8987
Gasket 4B8988
Can they be found at auto parts store
Mon, Mar 30, 2020 1:37 AM
Reply to zip:
Looks like the old type Ford master cylinder to me.
Mon, Mar 30, 2020 2:39 AM
4B8987 Plug [cap] is $11.92 from Cat gasket must be included, 4B8988 does not show but could have changed part #s check with Cat.
Mon, Mar 30, 2020 3:03 AM
zip
Ok that's not bad. 1961 Corvette uses the same but they want 55.00 so looks like I will get from cat
Mon, Mar 30, 2020 3:17 AM
Reply to zip:
Plug the number in to ebay!!!!!
Mon, Mar 30, 2020 4:42 AM
zip
Now the question is did someone put a different master cylinder on it in its lifetime my cap measures 1 1/4 outside of treads and I don't know what the cat one measures
Mon, Mar 30, 2020 9:41 AM
Thank you received: 95
Reply to zip:
seem to recall most of the M/C's or indeed most brake components, were Wagner or Lockheed.
Mon, Mar 30, 2020 12:30 PM
Reply to edb:
4B8987 is 1-1/4 UNEF which is 18 tpi.
Tue, Mar 31, 2020 3:41 AM
zip
Thank you OM that be what I'm looking for. You just clarified that
Tue, Mar 31, 2020 5:09 AM
